any way to correct water temp gauge?
Old Mar 16, 2003 | 01:24 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i installed my own white overlays on the gauges, came out nice but the water temp is off one or two lines i fear, is there any way to get it dead nuts or do i have to guess at this point? its a 91 bird lo3 and i have the fan switch disconnected so i cant do that trick =),maybe there is a way to hook up a temp gauge to the system some how?
Old Mar 16, 2003 | 01:56 PM
89cmrodriver's Avatar
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
maybe u can help me, someone had ran my fan off aswitch and iwant it to run like it did stock...do u know how to make i like that? but anyway, go to a advance auto parts or auto zone..or even a big lots, if u want quality dont get big lots but if its temperary then get a temp guage from big lots its like $5 and has instructions on how to install it..hope that helps
Old Mar 16, 2003 | 02:08 PM
wasp's Avatar
i got mine wired right into the fuse panel, ignition on fan on, ignition off fan off , same goes for tranny cooler fan........you say they have temp gauges at autozone? huh how would that hook into your water hose?
Old Mar 16, 2003 | 02:15 PM
Transmission: autos
ok i just went and looked at mine, theres a coiled wire (looks like a spring) goes from the temp guage through the firewall ad to te right of the neck that contains the theromostat theres a little thing that comes up about2 inches or so and has a bolt on top, mine runs into that, by the way i have a 2.8 v6, im not sure if the v8s are the same, i supposed u could run it where the theromostat is too, ya they have them at auto zone there about $12 there
Old Mar 16, 2003 | 02:20 PM
wasp's Avatar
maybe they make hand held gauge i could hook up to the water temp sensor ? yeah i have an lo3
Old Mar 16, 2003 | 02:22 PM
Transmission: autos
humm i dunno if this would work, my dad has these little therometers that he uses to check temps in ac systems,might work..
Old Mar 16, 2003 | 02:47 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I was looking at mine today. I don't have any overlays.. but the marks on the guage are not that accurate. the temp gun read just under 200 F at the thermostat area, and the guage was down at the mark between the 100 and 220 mark. I'm almost thinking of making my own white face overlays, and redo the marks to match a digital temp readout. or just replace it with an Autometer guage.. perhaps
Old Mar 16, 2003 | 03:02 PM
wasp's Avatar
lol, well how does this temp gun work? this is what im getting at, i want an accurate reading so i can reset the dash gauge, and id like to know the best way of going about this,ty
Old Mar 17, 2003 | 04:20 PM
wasp's Avatar
noone has any advice on this?
Old Mar 17, 2003 | 05:25 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
I just replied on a similar note in another thread on this board.
The stock temp guage is completely non-linear. When the needle just barely starts to move, thats about 150-160. By the time you get to a sliver above the 100' tick, thats actually closer to 170. The mark between 100' and 220' is actually about 190.
I've verified those numbers in my car with a scan tool (beauty of AD conversion, non-linear doesn't maytter anymore), and i've observed enough f-body temp guages with different temp thermostats to have confidence that they all act the same way.
In short, there is no point to trying to calibrate anything. All you need to know is what looks normal to you on your guage. If you normally cruise near the first tick and suddenly you're not, then you know you have a problem.
Old Mar 17, 2003 | 06:49 PM
wasp's Avatar
welp, this is what im gonna do, im gonna go out for a cruise with my dash apart so i have access to the needle, come back, pop the rad cap and stick a cooking thermometer in there, take the reading , turn the key on,set the gauge needle and everything should be kosher........what ya think?
Old Mar 17, 2003 | 08:34 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I hope you wear gloves after running the car hot and popping the radiator cap.
Old Mar 17, 2003 | 08:42 PM
Transmission: autos
sounds like a VERY BAD idea to me...dont do that, the antifreeze is VERY HOT! dont wanna hear about no one gettin burned, i guy i work with sometimes did that, burned his hands,arms,face, and another bad place...get my drift?
Old Mar 17, 2003 | 10:54 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
I have a 1992 Bird also and the way I have mine set is this......with the dash panel off and access to the needle.......I installed a C-4 Corvette 200* fan switch, after making sure radiator was filled, i let my car run to operating temp, when the fan switch kicks on at ..200*... I placed my needle on the 200 degree mark........so now everytime the ecm kicks on the fan I know the temp is 200*......I run a 180* stat with it and it runs very cool.....hope this helps you out.........hate to see ya doing the .........pop the radiator trick and get burned.......
Old Mar 18, 2003 | 05:09 AM
wasp's Avatar
nooooooooooooo......
you smother the cap with a rag and open it real slow to release the pressure, yeah you get coolant on the ground but it doesnt fly all over the place, lol can ya gimme some credit here
and chitown, i have my fans direct wired, i dont use a fan switch they are on all the time but ty anyway........
Papaginos
Sep 27, 2015 03:29 PM
Bstrang6
Sep 8, 2015 04:29 PM
Jote4805
Aug 25, 2015 06:11 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
