What does this hose that I broke do? (pic. inside)
Old Mar 17, 2003 | 11:39 AM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
See picture...
I'm not even completely positive that I actually broke it. The plastic "straw" that comes from the wiring harness came out of the little L-shaped boot. In other words, I can't tell that it actually broke-off because I can stuff it back into the boot. Plus, it looks like a clean break if it was a break at all.
I just want to know:
1. What does it do?
2. Is it okay for me to just push it back into the boot, or will that cause me a vacuum leak?
There is a possiblity that I might have a vacuum leak, and I want to make sure if this might cause it or not.
Attached Thumbnails What does this hose that I broke do? (pic. inside)-broken-vacuum-tube-small.jpg
Old Mar 17, 2003 | 11:51 AM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
Looks like a vacum hose for the vents or something.
Old Mar 17, 2003 | 12:31 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The vacuum line (straw) that runs to under the dash is for the heater/AC controls.
Yes it would give you a small vacuum leak and your heater control wouldn't work right. Try going from heat to defrost and see what happens.
Old Mar 17, 2003 | 02:46 PM
sancho's Avatar
Thanks for the replies.
Now, I'm just wondering if its acutally broken or not. Is the plastic tube supposed to be able to come out of that L-shaped rubber boot, or was it supposed to be permanently attached to the boot?
I just pressed it back into the boot, and it seems to stay.
Old Mar 17, 2003 | 02:52 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Just pressed on.. Should be fine.
Old Mar 17, 2003 | 03:30 PM
sancho's Avatar
Excellent; thanks!
Old Mar 17, 2003 | 05:38 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Vacuum hose for heater/AC controls + cruise control (if equiped).
You only need replace the original connection and try with the engine running (if all the heat/AC flow for only one "vent grille" in the dash, try again with the connection).
Pac J
May 17, 2020 10:44 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
wanext
Oct 6, 2015 12:18 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
