The new combo
Old Mar 20, 2003 | 12:12 AM
1983SS's Avatar
Car: 1983 "SS" Camaro, 2000 Mustang GT
Engine: .30 350
The new combo
Hey thought I would ask for some input on my new combo. The motor is a 4 bolt 350, flat top pistons that made 9.5 comp w/72cc heads. I was runnin a 600cfm edelbrock carb on top of a stealth intake. The new combo uses the same pistons and intake but thats it. The new combo I ordered is as follows: RPM heads 70cc configuration, the stealth intake and comp xe 268 cam. To top the intake off is a new speed demon carb with 750cfm and an electric choke. Any ideas on power output? The exhuast on the car consists of dynomax shortie headers into a single 3 inch exhaust. I was excited after ordering my parts so I thought I would post.
Old Mar 21, 2003 | 05:55 AM
1983SS's Avatar
Engine: .30 350
no opinions?
Old Mar 21, 2003 | 06:58 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Should make 390/410 gross hp. Your compression ratio may be lower than you think, unless the block was decked.
The piston usually sits a little below the deck on a stock block.
this has to be accounted for in the cr calculation.
If the block has been true "0 decked" then you'll be fine.
You can also juggle head gasket thicknesses to get the cr where it needs to be.
Alumium heads usually can tolerate and need a little more compression than a cast iron head.
10.0:1 to 10.5:1 would be better. I'd of ordered the 64cc heads.
Should be a real nice improvement over stock smog heads.
Compression ratio Calc
HardCore HotRods
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
roysatikas
Sep 22, 2015 08:15 PM
z28guy134
Sep 1, 2015 11:50 PM
