passenger floor board soaked.
Old Mar 20, 2003 | 07:00 PM
Sleipnir's Avatar
i searched the message board for something on this, buuut, my front passenger floor board is just soaked in green stuff, its not engine coolant and i didnt spill nothing there, it feels like it trails up to under the ac controls kinda, a bit farther back, anyone know what this could be? freon something crazy???
Old Mar 20, 2003 | 07:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's engine coolant. Nothing else is green. Believe it.
You need a heater core.
Old Mar 20, 2003 | 09:27 PM
chitowncruiser's Avatar
Car: 1996 Camaro
Engine: 3800 V-6
Transmission: 4L60E Automatic
......................change that heater core at once........mine did the same thing except I was going down the freeway when it blew................you might as well get you a case of brew and some bandages for your knuckles also............:lala: :lala: :lala:
Old Mar 20, 2003 | 10:36 PM
Sleipnir's Avatar
doh, lemme guess, just lemme guess, do i have to take the console out pretty much?
Old Mar 20, 2003 | 11:19 PM
88ROC1LE's Avatar
I see a heater core swap in your future. It's not real easy, but can be done. I believe the dash will need to be removed, IIRC, correct me if I'm wrong guys! It's been a while since I swapped mine.
Old Mar 21, 2003 | 01:48 AM
rezinn's Avatar
Mine went out a couple years ago and I didn't have time to fix it, so I just bypassed it by connecting the two hoses connecting to it with a U shaped piece of pipe. I had it like that for three months. You could do the same if you can't fix it right away.
Old Mar 21, 2003 | 05:33 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
You can bypass the heater core as mentioned in the previous post, if you can live without heat. But the heater core will definitely have to be replaced.
The job is not difficult, but time consuming and you will have to bend and twist to get your hands in some pretty small areas. Some people had to remove the dash, others didn't. I had to completely loosen my dashboard to get enough room. Give yourself an entire day and make sure you keep track of all the screws that you have to pull. Its a pretty straight forward job if you have a manual.
Old Mar 21, 2003 | 09:32 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I just found out mine is also blown. suckors
Old Mar 21, 2003 | 10:53 AM
KC10Chief's Avatar
Yup. Heater core. Sucks to be you. I've never done one on a third gen, but I have yet to meet a heater core that would be fun to replace. You can do it though. Pretty straight forward. Better clean that carpet after you're done! Matt
armybyrd
Sep 21, 2015 10:28 PM
F-body-fan
Sep 19, 2015 09:02 PM
ctoledo0834
Sep 18, 2015 04:16 PM
IROCZDAVE (88-L98)
Sep 17, 2015 05:46 PM
3.8TransAM
Sep 17, 2015 02:16 PM
