Roller Rockers - Valve Springs
Old Mar 21, 2003 | 11:45 PM
smithtc's Avatar
I'm finally getting around to that last series of mods I wanted to do to my 185,000 mile 350 powered GTA before beginning an engine rebuild (spare motor). Currently I'm adding headers, and a cutout. After that I was planning on Pro Magnum Roller Rockers 1.6 ratios from Comp. What risk am I taking running using the stock Valve Springs?
Old Mar 22, 2003 | 06:23 AM
ede's Avatar
ede
stock springs are trash and if they have any age to them they're even bigger trash. if you're building a replacement engine i wouldn't bother with swapping rockers or springs now. the gain will be slight and most likely unnoticable on a stock engine. if you want to swap springs go with a set from comp or lunati for cam with a lift in the .46 range and buy retainers to match the springs and trash the factory rotator set up.
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
Dialed_In
Aug 20, 2015 01:45 PM
IrocZ'85
Aug 17, 2015 06:24 PM
