Found limits of 163k Stock Short Block
Old Mar 22, 2003 | 03:22 AM
Chris B's Avatar
Well finally got the time to teardown the motor after it decided to let go at the track. Specs on the motor are/were: Stock Short Block---Pistons, crank and rods. Corvette L98 alum heads, Lt4 hotcam, and NX 150 shot. Pics can be seen at: BROKE SHORT BLOCK. With all the damage it looks like I was spraying but this was in 2nd gear before the spray comes on. Never the less, I have a forged shortblock ready to go in and the heads are already being fixed/upgraded with bigger valves/port/polish/chamber work. Swapping to a 2 stage NX setup on a HSR as well.
Old Mar 22, 2003 | 09:05 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
all i have to say is....wow.
-Brian
Old Mar 22, 2003 | 09:32 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Ouch !!!!!!!!!
Old Mar 22, 2003 | 10:18 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
that ain't nuthin' that a lil JB Weld can't fix! (insert sarcasm here)
Old Mar 22, 2003 | 11:16 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
DAMN POS stock crap.
can't even handle a little 150 shot :sillylol:
Old Mar 23, 2003 | 02:26 AM
crazycrocket's Avatar
Car: 1985 camaro
To think I had my engine with 165 000 kms on it reved out, off the tach, to the point of I could hear tapping and it is still alive, running almost as good as the day I bought it. I tried to destroy it but it still runs strong.... Damn ain't that just the luck, when you want it to live, it don't when you don't it does. Sorry to see yoy got bad luck man.
Old Mar 23, 2003 | 06:50 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Makes me want to run out and buy a little NOS...
Old Mar 23, 2003 | 08:02 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
You know, there are less destructive ways of checking the thickness of your cylinder bores How fast were you spinning that thing when it let go? And what failed? A piston?
Old Mar 23, 2003 | 09:01 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Hey..... that one of them there Variable Piston engines, ain't it?
Sometimes ya got 'em, sometimes ya don't.
anesthes
Mar 10, 2016 10:35 PM
Reddeath210
Oct 6, 2015 08:20 AM
camaro71633
Sep 1, 2015 10:24 AM
BBSDesigns
Aug 11, 2015 07:39 PM
antares57
Aug 6, 2015 07:47 AM
