Is this the cold-start switch?
Old Mar 23, 2003 | 12:57 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
This was located in the front of the intake manifold. I had thought that it was a temperature sending unit, but everyone seems to say that it's for the cold-start injector. Is this true?
Old Mar 23, 2003 | 01:20 PM
Vader's Avatar
Blue86,
Yes, that is the Cold Start Control. It operates the cold start valve (injector) on a temperature and time basis. You should have found it here:
Old Mar 23, 2003 | 03:53 PM
blue86iroc's Avatar
Car: 1986 IROC-Z
That'd be correct. Thanks, Vader!
Old Mar 24, 2003 | 02:53 AM
ilku's Avatar
Cold start problem
I have cold start problem in my '87 GTA.
How could I check that cold start control? Or should I buy new unit?
When the air temperature is below zero, the engine doesn't start.
When the engine is hot or air temperature isn't below zero, the engine (L98) starts fine. I think that's very mysterious problem...
Is there any units that is should check?
Old Mar 24, 2003 | 05:50 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Ilku, probably your best bet would be to post a new topic with that question or do a search on the cold-start equipment. This thread was intended to identify a component.
Unfortunately, I never spent the time to learn indepth how the cold-start system works.
Old Mar 24, 2003 | 06:59 AM
ilku's Avatar
Allright...
thanks blue86iroc
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
