Auto Tranny hard to shift when
Old Mar 24, 2003 | 10:06 PM
Firebird90V6's Avatar
Question what would make a transmission hard to shift when its parked facing uphill. It only happens when the car has been sitting overnight. Any help guys. I just replaced the Tranny mount and it its installed correct. possible a tranny mount or something else? Any help would be apprcitated.
Old Mar 24, 2003 | 10:27 PM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
The tranny is holding the car from rolling back. So you have the weight of the car fighting against you, making it hard to get out of gear. I've had to nudge a car back uphill once to get it to come out of park. The best way to avoid this is to set your e-brake, let the car rest on that, and then put it in park. Avoids all this being stuck in park issue, and keeps the e-brake freed up. Try it some time.
Old Mar 24, 2003 | 10:31 PM
HMMM
Ill give that a try thanks for that infomarion anybody else got some opinions. And i take it its nothing to be deadly seriouse about. Maybe you can help witht this problem. I feel a slight thud or clunk everyonce inwhile up by my feet on the driver side when i let off the gas at some points. Its only happens at some points any ideas?
Old Mar 25, 2003 | 11:23 AM
Vader's Avatar
What ATC said. See thet lever next to the shift lever? Use it. There is a lot of presure on the parking pawl when parked on an incline, and it can take a lot of effort to disengage it.
Old Mar 25, 2003 | 12:25 PM
atc3434's Avatar
Car: 1986 Camaro SC
The clunking sound might be a tranny mount... or the neighbors cat! Its possible it could be slop in driveline somewhere too... Check your universals and rearend to see what kind of play you have...
Old Mar 25, 2003 | 08:24 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i agree with the parking break reply.....letting the car rest on the tranny cant be good..specially from the thunk you get trying to put it in drive...move to central flrorida..nice and flat
Old Mar 25, 2003 | 08:35 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
happens to me every time I go to my Moms'..set the parking brake then shift into gear...problem solved.
Azrael91966669
25
Jun 20, 2017 04:04 AM
someone972
Aug 30, 2015 12:52 AM
spaigo
Aug 21, 2015 07:46 PM
crazynights
Aug 21, 2015 06:53 AM
