jersey starts obd 2 emissions june 1
Old Mar 24, 2003 | 10:48 PM
thatsme's Avatar
New jersey is starting obd 2 emissions in place of the dyno test on june first for 96 and up. The south brunswick station is already doing it. If your Check engine light is on it will be a failure. If you cleared the codes while you were waiting in line it will also be a failure. If you want to avoid the test make sure you go before june first. You are allowed to inspect 2 months early. I figured I'd let everyone know. You have a better chance passing the dyno than the obd test
Old Mar 25, 2003 | 11:20 AM
Vader's Avatar
If you cleared stored and pending codes befoer you hit their tester, how are they going to know? I have several OBD-II vehicles, and I have the option of turning off the MIL or clearing the codes completely. Once they're gone, they're gone. There is no way I know of to retrieve them. This ain't Windows XP - you can't "undelete" the DTCs.
Old Mar 25, 2003 | 12:22 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Vader, you sitting down? OBDII also reports whether the malfunction diagnostics have been run. So when you clear the codes you also clear the flags that state the ECM's OBDII diags have been run.
All diags not run, you fail.
Texas is doing this and it is a royal pain for some folks. The EGR diag for some cars almost never gets run, and they can't get their cars to pass the OBDII scan.
RBob.
Old Mar 25, 2003 | 12:30 PM
NJITIROC's Avatar
Car: 1989 IROC-Z
i thought our cars dont have an OBDII computer
not sure though
Old Mar 25, 2003 | 01:15 PM
Vader's Avatar
RBob.
Right, but on the way to the test station, you should get a diagnostic routine. I didn't take literally the part about "clearing codes while waiting in line". Anyone sitting there with a laptop stuck to the port would be a red flag for me, too.
I thought the Tech-II allowed a forced diagnostic routine ¿?
Old Mar 25, 2003 | 02:40 PM
kane91z's Avatar
Car: 91 Z28
Engine: 5.7
welcome to cali
Old Mar 25, 2003 | 03:03 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
good thing i dont own a newer car....
Old Mar 25, 2003 | 05:35 PM
ronterry's Avatar
Car: '94 Corvette
Anybody ever think about making a fake connector to shoot 40volts back at there machine...
OBDII Virus
Ron
Old Mar 25, 2003 | 10:10 PM
drive it's Avatar
OBDII Virus
Ron
I'm still laughin'!!!
Old Mar 25, 2003 | 10:49 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
why stop at 40 Volts - That must be what power inverters are made for!
Old Mar 25, 2003 | 11:14 PM
thatsme's Avatar
New Jersey fails if any of the diags come up not ready or not run. This will fail people who legitamately reset the codes or had the battery disconnected for some reason. Its going to really suck for the people who left their gas cap loose and triggerd a code. I've heard it take up to 50 key cycle to clear it on its own.
Old Mar 26, 2003 | 02:01 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
dont feel bad, California will probably have it the worst out of every1. Just like always
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
