Cam ?
Old Mar 25, 2003 | 03:03 PM
84s/e's Avatar
Car: 1984 Firebird S/E
Engine: 5.0 lg4
Cam ?
I have a 305 lg4. I'm planning on a cam swap and want to know what would be the best for stock TC and 3.08 gears. I also have the stock heads am thinking about getting some work done to them. I want something that would be good to drive everyday too.
Old Mar 25, 2003 | 04:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The Crane Compucams are great. For a stock TC, the 2030 is about all you'd want to do (Summit p/n CRN-114122).
But, why limit yourself so? With the low compression of the early LG4, you can get by with a lot more cam. The few extra bucks a higher stall TC will cost you will be well worth the expense. The results will be most gratifying. Note that I drive mine daily, through the winter no less.
This assumes you go through with your head upgrades (porting, springs should be considered must-do, screw-in studs an excellent idea), and that you ABSOLUTELY do exhaust and air cleaner upgrades.
Old Mar 25, 2003 | 04:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Comp XE-256 for +TQ or XE-262 for +HP.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
