Intake Manifold Dimensions
Old Mar 26, 2003 | 09:33 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Does anyone know the dimensions for a regular small block chevy manifold? For instance, if I were to lay down a manifold flat, how long would it be?
For example the intake looks like..
\____/
what would the dimensions be if it looked like..
_______
Also, what is the angle of the intake port/head mating surface?
Old Mar 26, 2003 | 10:24 PM
Vader's Avatar
Thinking about a custom sheet metal intake, are we?
The width of the base is 5.962", and the faces of the heads are 2.40" each, making the total length 10.762" (remember to consider the radius of the bends when calculating total length). The angle of the head intake flange to the cylinder deck is 80°, so the angle of the intake flanges to the lifter valley end walls (China Walls) would be 35°. In other words:
Old Mar 26, 2003 | 10:28 PM
Sonar_un's Avatar
Car: '86 T/A
wow.. thanks a million
Old Mar 27, 2003 | 08:14 AM
Vader's Avatar
Just a little more to consider - the compressed thickness of a typical intake flange gasket is aroud 0.062", and you'll need to leave some space under the intake for sealant/gaskets as well.
Old Sep 21, 2003 | 01:10 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
hey vader, got any more measurements and tips?
im about to start attempting my first intake too..
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
