Mass air flow Sensor
Old Mar 27, 2003 | 10:05 AM
Eat_um_up's Avatar
My car keeps giving me the check engine light when the car gets hot and the code is for the MASS air flow sensor. The car is a 85 v6 MPI. I have replaced the mass air flow sensor and put a new computer in the car.
It still gave me the trouble so i put prom chips from a 86 chevy beretta with the same engine in it. still no change.. What other options do i have?
Old Mar 27, 2003 | 10:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Check / replace the MAF pwer relay and the MAF burnoff relay
Old Mar 27, 2003 | 11:09 AM
Vader's Avatar
And since the V-6 engines only have a MAF power relay (no burnoff), half the work is done for you. Chances are you have a failing relay, poor relay connection, poor electrical connection at the MAF, poor engine grounding, leaking intake ductwork between the MAF and throttle body, or a vacuum leak on the engine.
Exactly what error code did you retrieve?
Old Mar 27, 2003 | 11:25 AM
Eat_um_up's Avatar
it is a code 32 if i remember correctly. where is the maf power relay and what does it look like? My guess is that is where my problem lies.couse ive replaced everything else to get this thing to pass smog.
THanks
James
Old Mar 27, 2003 | 12:39 PM
Vader's Avatar
You'd better re-scan and verify the error code. a DTC 32 is NOT for a MAF error.
The MAF relay should be located on the firewall near the power brake booster. It should have a connector with four wires - a black/pink striped wire, a black/white striped wire, an orange/black striped wire, and a brown wire. A replacement relay is usually about $10.
Old Mar 27, 2003 | 02:06 PM
Eat_um_up's Avatar
thanks vader, i think i know what your talking about and i will try replaceing it. It might not be a code 32. it might have been a 34. This car has had so many codes come up in the last month that i get them all confused.
Old Mar 27, 2003 | 02:23 PM
hank's Avatar
I agree a code 32 is an EGR code
Old Mar 27, 2003 | 04:04 PM
Eat_um_up's Avatar
Well i cant seem to find the MAF power relay. can ayone take a picture?
Old Mar 28, 2003 | 10:48 AM
Vader's Avatar
EUU,
In further researching the V-6 scheme, I discovered that the MAF relay is located near the battery, on the radiator shell/support. There is also a MAF fuse located along the inner fender just behind the battery. The wire colors I indicated for the MAF relay are correct.
eightsixseven
Dec 16, 2024 01:50 PM
chazman
Aug 28, 2018 03:25 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
