Timing Chain
Old Mar 28, 2003 | 09:41 AM
Stu162's Avatar
Timing Chain
I have an 87 z with an LG4 and I need a new timing chain but cant get to summits site to find the part number.Does anyone know the part number?
Old Mar 28, 2003 | 09:55 AM
Vader's Avatar
Not knowing what kind of chain and sprockets you want, it would be difficult to give a part number.
Beyond that, there are a lot of places other than Summit that have timing sets. Some are probably in your yellow pages.
Old Mar 28, 2003 | 10:22 AM
Vader's Avatar
If you're not sure what you want, I'd suggest a Cloyes 3100 or Miloden 15016 roller/roller timing set. They're about $60. If you want to spend more dollars, check Comp Cams at http://www.compcams.com/catalog/323.html
For others, look here:
http://www.competitionproducts.com/
http://www.northernautoparts.com/
http://www.pawinc.com/
http://www.wdautoparts.com/
http://www.sdpc2000.com/
Old Mar 28, 2003 | 10:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
May I correct a rare mis-step on Vader's part....
The set you need would be a 3136, since your 87 should have a roller cam. The 3100 is for non-roller motors. You might want to take off the cover and look before you order anything, just to be sure.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
