camaro vs. firebird hood clearance?
Old Mar 28, 2003 | 01:12 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Is there a difference? My trans am has a carbed 305 with the L69 dual snorkel air cleaner. In the suspension board, there is currently a post where a Jamex STB can be installed over top of the air cleaner with the same air cleaner I have, but it was in a camaro. I know that just looking at my car with the hood open, I can't see how there would be room for anything else above the air cleaner. Oh yeah, it has a stock 4bbl intake. Is there more room under the hood of a camaro?
Eric
Old Mar 28, 2003 | 01:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
When i had both side by side I could swear the FB had a 1/4 inch more clearance then the camaro.
Old Mar 28, 2003 | 03:26 PM
1986redbird's Avatar
there is a difference in the two, the firebird's nose is more angled than the camaro which would make the hood closer to the air cleaner. I have a factory carbed LG4 with the factory aircleaner and there is an indention in the hood insulation from the aircleaner.
Old Mar 28, 2003 | 03:32 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
Okay thanks. It confirms my suspicion that putting on an STB that goes over the air cleaner probably wouldn't be a good idea.
Eric
Old Mar 29, 2003 | 11:26 AM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Eric:
Did your TA have the functional air scoop and if so did you have to remove the mechanism that opens and closes the scoop in order to get the dual snorkle set up in there.
I have an 83TA with funtional scoop and if I can find a dual snorkle I'd like to still have hood scoop opening when needed.
Thanx.
Old Mar 29, 2003 | 01:50 PM
Eric's85TA's Avatar
Car: 1985 Trans Am
Engine: 400
Axle/Gears: 3.70
No, I have the later style Trans Am hood with the two center air vents in the front and the air extractors off to the sides in the rear. I'm not sure what you'd have to do with one of the functional hood scoops.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Randomtask2
Aug 13, 2015 01:57 AM
