Is it nessessary to replace dist. gear when changing cams?
Old Mar 28, 2003 | 08:51 PM
R.O.B.'s Avatar
Not to sound like a cheapskate, but the gear runs $30.00. I'm sure its a good idea to do it at the same time, but if I don't, and the gear looks like its not worn out, will it be ok, or will it wear out the cam gear?
Old Mar 28, 2003 | 09:13 PM
jeffsbluez's Avatar
Car: 91 z28
What type of cam are you running? If it is a hydaulic flat tappet cam with your stock "86" distributor then no. If you are running a roller cam with your "86" distributor then yes.
Old Mar 29, 2003 | 08:14 AM
ede's Avatar
ede
you need a bronze gear with a billet roller cam, note the word billet, a steel gear will work just fine with any other cam, including a factory roller.
Old Mar 30, 2003 | 07:39 PM
R.O.B.'s Avatar
I am running a Clevite(sp?) cam with the same specs as a Crane Compucam2030. It will be installed in my 86, non-roller 305.
jklein337
Sep 19, 2018 06:23 PM
apo_bailon15
Mar 28, 2016 05:20 AM
camaro71633
Sep 1, 2015 10:24 AM
mizz0313
Aug 12, 2015 06:45 AM
Fronzizzle
Aug 9, 2015 01:15 PM
