Making a Phenolic spacer?
Old Mar 28, 2003 | 10:18 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
I want to know what grade of phenolic laminate/Garolite can I use to make a spacer for my intake? BBK makes them for the stangs and think I've seen them in the lingenfelter catalog for the ZR-1's upper/lower. I just need to know what grade will withstand the heat and cold variences.
Old Mar 28, 2003 | 10:22 PM
Damon's Avatar
I used to make mine out of WOOD, believe it or not. It's actually a great material- easy to work with, transfers almost NO heat up from the intake.
Downside: they get fuel-logged over time. Hitting them with a coating of some sort would probably help prevent this, but I never had them on that long and never went searching for a long-term fix for this problem, although I'm sure one exists.
Old Mar 28, 2003 | 10:27 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Wood???? Wow, that was the last thing i would have ever thought of.
Old Mar 29, 2003 | 07:29 AM
ede's Avatar
ede
i agree wood is the way to go. i use birch ply wood for mine.
Old Mar 29, 2003 | 07:44 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Wood has been used for these for a very long time, it works very well, but they have to be replaced every so often because the hot cold cycles will cause the wood to crack over time.
Old Mar 29, 2003 | 12:02 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
I just dont see wood being that astheticly appealing on a engine that is full of chrome. I'd like to use phenolic laminate/Garolite, or maybe aluminum.
Old Mar 29, 2003 | 02:26 PM
Vader's Avatar
Aluminum? Only copper transfers more heat than aluminum (among the "common" metals).
Old Mar 30, 2003 | 12:49 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Alwright So no aluminum.
So Mr. Vader with all your infinate wisdom maybe you could give me the answer I am seeking. What grade phenolic laminate do the manufacturers use to create phenolic spacers??
Old Apr 2, 2003 | 03:15 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
ok. so does anybody else know? Please don't force me to go and ask sombody on a mustang forum.
Old Apr 2, 2003 | 05:22 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Try looking in the Holley carb catalog, and the catalog for Dart heads, or World Products, can't remember which. I think they all make intake spacers.
Old Apr 3, 2003 | 08:03 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
standard spacers are 3/8" thick, I need 1".
Old Apr 3, 2003 | 12:42 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I tried making one out of polyester laminating resin and some kevlar cloth, it didn't work for long, it compressed and leaked.
I also made one from plastic. I can't remember what the stuff was called, it was similar in texture to plastic milk jug material but higher temp resistance. That one is working well to this day. Go to someplace where they sell plastics and they ought to be able to steer you in the right direction.
I've noticed that there are wooden spacers commercially available, so it must not be that far fetched an idea. Some time I'll probably try making a wood one too.
BTW spacers do help performance.
Buying one isn't a bad option either. Jegs has a bunch.
Old Apr 3, 2003 | 01:16 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i got a 2" phenolic spacer off ebay for 20 bucks shipped. it was brand new to. might try there first.
Old Apr 3, 2003 | 01:45 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There isn't really any such thing as a "standard" spacer, they're available in all kinds of heights up to several inches.
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
Horridbulldog
Wheels and Tires
Feb 13, 2016 07:22 AM
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
