this is just strange!!!what is it?
Old Mar 31, 2003 | 05:52 AM
icebird_1981's Avatar
i really need your guys help on this one, i got pulled over 3
times last night because my front lights. k well when i turn on my head lights the passanger side light comes on but not as bright as it should be and the driverside is really really low, can barley see it (like a faint red colour). now if i put it on highbeam the passanger light goes out and the drivers side goes on highbeam. also while i have the lights on high beam or not
the little blue high beam light between the signals is always on. what should i do???
Old Mar 31, 2003 | 07:22 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
I would start by checking for a loose headlamp ground. The high beam light has me little thrown as to why it would be on all the time.
Old Mar 31, 2003 | 07:27 AM
mc85ta's Avatar
loose ground
corroded wires (most likely the cause as ALL firebirds have them almost broken). Pull the connector off the headlight and check those wires
but since it's acting so weird it could be a wireing issue as well where something is shorting out , but who knows.
I would look around and in the worst case I Think there's a tech article on this board on how to make your own headlight harness , taht might solve your problem.
Old Mar 31, 2003 | 08:13 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
Hmmm, weird. You must look like that space ship from Close Encounters coming down the road . Do you have all the right bulbs in there? After we painted my car and the shop reassembled everything, I had some crazy stuff going on with my brake lights. Dim, bright, on, off...never had a problem before, either. It turned out that all it was was the wrong brake light bulb put in during reassembly. Once we pulled it and put the right one back in, everything was fine again.
Old Mar 31, 2003 | 09:00 AM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
I had the same problem, dim lights and the high beam light on in the dashboard. It wasn't on a firebird, but the wiring harness had heated up and melted creating a condition where the low and high beam wires were touching dimming the lights and making the high beam light go on on the dash. Hope this helps.
Old Mar 31, 2003 | 09:08 AM
laiky's Avatar
sounds like a bad ground or shorted damaged wiring. Check for a ground first. Connect a clip lead to the black wire on the headlight socket and ground it. If that helps you have a bad ground. has anybody screwed with the lights lately. It also sounds like the wires are mixed up in the sockets.
Old Mar 31, 2003 | 10:13 AM
Jim L. Saylor's Avatar
Car: 1983 z/28 t-top
Engine: 305 Carb LG4
Transmission: 5 speed
Yeah...I had the same problem last year...YES...check all the grounds, but mine ended up being a shorted bulb in the instrument cluster. Could also be the headlamp switch itself. Test it with a good one...if you need one I have one I could send you to test... The cluster comes out FAIRLY easily...once you get the hange of it...I have mine out 20 times at least...could do it in minutes...
Real PIA diag'n these types of problems...
Jim
Old Mar 31, 2003 | 03:53 PM
thanks for your guys help i found the problem one of the 3 wires that go in the headlight came out some how. put it in and now everything is back 2 normal.
Old Mar 31, 2003 | 07:15 PM
laiky's Avatar
was it a black wire?
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
