Car Died In 3rd
Old Apr 2, 2003 | 03:08 AM
AstroturfHead's Avatar
Car Died In 3rd
Hey so I was taking my friend for a ride in my bird today. I hit 65 or so on a straightaway and at 4500 RPM or so I dropped it into 4th or 3rd and the tach died and the car turned off.
After costing to a stop, no noticable problems were present. Battery was reading low but working, temp normal, oil normal. It will turn over and it sounds like it wants to start. We think its Ignition Coil. What do you think?
We put a screwdriver in the end of the coil line (distributor end) and groudned it on headers and got no spark. When I replace the Ignition Coil, how much do I replace? Also, what codes should the computer throw?
Thanks guys
Old Apr 2, 2003 | 05:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably not the coil.... more likely the module.
Take them both to a parts store that can test them, avoid unnecessary expense if possible by getting only the parts you need instead of the "maybe it's this, maybe it's that" method of troublshooting.
Old Apr 2, 2003 | 12:16 PM
I pulled the code today - Code 74. Ignition like I thought
Then I probed the sensor from the module, the black connecter attachted to the coil. Its voltage was a good and it pulsated like normal. I've determined its the coil. Any disagreements?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
killer777
Aug 8, 2015 02:47 PM
