Tune up problems
Old Apr 2, 2003 | 06:03 PM
cowboy67's Avatar
Tune up problems
Howdy all,
I have an '84 Firebird. The other day I tuned it up by replacing the following parts:
Plugs
Wires
rotor
Distributor cap
PCV valve
Fuel filter.
Now my problem:
I took it down the road and it is not running all that good. When I give it gas and it sputters(?). I am thinking that it could be a bad plug or wire? Could any of you give me any ideas on where to look? When I get up to my cruise speed, 55 - 65 MPH it seems to run fine. This problem was not there until I changed the plugs and wires.
Any help would be greatly appreciated!
Thanks,
Jim
Old Apr 2, 2003 | 08:06 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
did u put the wires on right? double check the firing order, u might have screwed the order up. if not, make sure all your plug wires are snapped onto the sparkplugs. u got to push it till they snap in place, and they should be hard to remove if they are on right.
Old Apr 2, 2003 | 08:12 PM
fast86z28's Avatar
Car: 91 Z28
Engine: LB9
Transmission: WC T5
yea sounds like you either screwed up the firing order, or your timing could be off too, did you move the dist.?
Old Apr 3, 2003 | 08:59 AM
Vader's Avatar
I know it's a little off-the-wall, but what replacement PCV valve did you use?
Old Apr 3, 2003 | 09:18 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
I'd systematically put the old parts back on, one at a time, until you narrow down the problem. Start with the easy stuff first, like the PCV valve and distributor parts. If you don't notice a change with the old part, put the new one back on.
You might also want to make sure that the wires aren't shorting out on anything. One time, my stock wires melted onto the exhaust manifold and caused a miss.
Old Apr 3, 2003 | 10:27 AM
cowboy67's Avatar
thanks for all the great responses. I found what was wrong. I took all the plugs out and inspected them. And darned if it wasn't the last plug. I was pulling the wire and half the darn plug came with it. I cleaned and put one of the old plugs back in and walla, Works like a charm.
Thanks all!
Jim:lala:
Street Lethal
Apr 30, 2019 12:14 PM
nuggie
Aug 25, 2015 01:27 PM
soarestransam
Aug 24, 2015 08:15 AM
ezobens
Aug 19, 2015 10:29 PM
zeitghaist
Aug 18, 2015 07:33 AM
