Power estimates
Old Apr 3, 2003 | 10:47 PM
jdrafke's Avatar
Power estimates
zz4 short block w/ edlebrock victor junior heads, and a crane cam powermax 272-2(Strong low & mid range torque, daily driving. Good idle. RPM range 2000-5000. Cruise RPM 2600-3000. Comp. 8.7-10.7:1.) camshaft, zz4 intake manifold, and a edelbrock 600cfm carb(i know its too small but gotta sacrifice power for a little gas).Anyone know what kind of hp/torque guess this would be with the 600cfm carb.
Old Apr 3, 2003 | 10:48 PM
jdrafke's Avatar
O and a pair of edelbrock headers
Old Apr 3, 2003 | 11:37 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Still lots of variables, but should be over 300 under 400 at the fly. 400 would be easy to break, but a bigger carb and high comp ratio needed.
Old Apr 3, 2003 | 11:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is a terrible mismatch. The carb is too small. The heads are too big for the rest of the combo.
The ZZ4 intake port measures 1.887 x 1.101" (at least the one in my garage does). It matches to a 1204 gasket when ported out. I don't know the dimensions of a Vic Jr intake port offhand, and Edlebrock's site seems to be down; but for comparison, a Dart Pro 1 215cc head (same intake runner volume) has port dimensions of 2.15" x 1.19".... over ¼" taller, and over 3/16" wider. It port matches to a 1206 gasket, 2 sizes larger. The ZZ4 manifold might not even completely cover the ports on the heads.
A set of Performer heads would be a better match for the other parts. Performer RPMs would be OK if the carb was right-sized to at least a 650, and preferably a 750; if you want to go with a carb that limits the motors top end to 5200 RPM or so like that one will, you don't need huge flow in the heads. If it can't get through the carb and intake, it doesn't matter how big the heads are.
Old Apr 4, 2003 | 02:50 PM
jdrafke's Avatar
k
k so if i went with a performer rpm manifold w/ performer rpm heads, a holley 650 and the crane cam how much horse power do u think i would be able to pull at the wheels
Old Apr 4, 2003 | 05:16 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Thats a much better combo, you might get 300 at the wheels. But there are still lots of varibles. You should try using a program like desktop dyno.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
