Do I need starter shims?
Old Apr 4, 2003 | 07:37 PM
RICHRAD's Avatar
When I removed the starter I discovered no shims, The starter is fine, just took it out of the way to drop the oil pan for the cam install. Well, probably is the first sbc I took a starter off. Always been Pontiac v-8s in the past and remembered them having shims. It cranked the motor just fine before the teardown. Is any at all required just to be safe?
Old Apr 4, 2003 | 07:47 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
If it started fine before it should still be the same, unless you change starters. I've only worked on 1 small block chevy that needed shims and that was an old 70 C/10 pickup, I finally got it shimmed correctly. I hear newer trucks all the time that sound like they need them, nothin sounds the same as a chevy that needs shims
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
