Sucking Sound?
Old Apr 9, 2003 | 03:32 PM
400 SB Iroc-Z's Avatar
Sucking Sound?
My car is making a sucking sound that seems to be coming from the back of the eingine. It is always there when i accelerate. Anbody have any ideas. THANKS
Old Apr 9, 2003 | 03:33 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
does it run ok?
could be a vacuum leak...
-brian
Old Apr 9, 2003 | 03:36 PM
CrispyClutch's Avatar
I thought carbs made a sucking sound normally...
Old Apr 9, 2003 | 07:17 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
yup......
Old Apr 9, 2003 | 07:39 PM
ED Andrews's Avatar
What you can do is use a spray bottle of water and spray around the area that you think it is sucking from while the engine is running.
If the sucking stops then you can narrow down where it is. I bet it's between the carb and manifold.
Of course this only will work on small leaks.
Old Apr 9, 2003 | 10:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Actually carb cleaner is easier to use.
Spray just a small amount using that long red straw to aim it just right. If the engine revs a little higher, you've got a vacuum leak. If it doesn't, you don't.
Old Apr 9, 2003 | 10:42 PM
Blown87's Avatar
Car: 87 Z-28
Engine: 383 HSR w/supercharger, AFR heads
Transmission: 700r4 w/2500 stall
Axle/Gears: 3:73
Vacuum sucks.
Old Apr 9, 2003 | 10:47 PM
the car runs fine, I have had it for about 7 months now and it never made any noise like that before. I will try the carb cleaner.THANKS
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
3.8TransAM
Oct 1, 2015 07:47 PM
