Heat soak on Starter?.....
Old Apr 10, 2003 | 09:07 AM
mostang's Avatar
Hello, I post a question yesterday about my car not starting after it gets warm I changed the key because ours was very warm but that did not help.............
Everyone mentioned Starter heat soak as well..............
When the car will not start it does not make a sound no click click
no nothing..........does the heat soak they mentioned do that?....
and what is the fix for this?.....Thanks, Bob
Old Apr 10, 2003 | 03:38 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Yes, heat soak can cause this. The heat affects the solenoid which is where the clicking normally comes from.
You can pick up (or make if you prefer) a heat shield to keep the heat off the starter.
Old Apr 10, 2003 | 06:55 PM
gtabadboy's Avatar
Im pretty sure its heat soak. This happened to me for years and I was always thinking the key too - it isnt!! You have a couple options:
1. Heat wrap by DEI
2. Get a heat shield that mounts to the starter.
3. Get a remote mount starter mount (this is cheap and easy and worked great for me. Summit makes a kit maybe 25 bux).
All are available at Summit but the remote mount will definately solve your problem.
Old Apr 10, 2003 | 10:39 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I've always heard of heat soak but the only time I ever has a problem with a dragging starter (or a delayed start after several clicks) was with weak starters. Two times in 25 years between 9 vehicles (only 2 with headers) I've had a hard to start when hot problem. One car had headers, the other did not. On both the installation of a new start cured the problem. If a heat shield helps great. Just my two cents.
Wow, nine vehicles in 25 years sounds like a lot, but I still have 7 of them (81 Z28, two 86 IROCs, 73 Laguna, 2 blazers and a Jeep). Notice the blazers and jeep are not identified in detail giving you a clue that they really aren't that important to me. Once of the blazers will be sold this summer to make room for a pickup. I won't miss it unless the PU gets stuck this coming winter.
Old Apr 11, 2003 | 07:29 AM
ede's Avatar
ede
if you have a problem wuth "heat soak" what you really have is a weak starter that needs replaced.
Old Apr 20, 2003 | 11:45 PM
caleb's Avatar
Car: 89' Iroc
so is it the starter or the silonoid that causes it not to work, cus i want to get the remote mount silanoid kit but If its the starter thats the problem I will save the money and get a high torque minnie starter.
Old Apr 22, 2003 | 10:53 AM
gtabadboy's Avatar
Unless your motor has a high compression ratio maybe 10.5:1, you will not need a high torque starter. I would start with the remote selenoid and hook it up to your starter and see how it works. If you are still having problems then buy a standard starter at autozone (if there is one near you), they offer a lifetime warrantee on their starters. This starter should be sufficient for your motor. Another option is to just pull your starter out and get it checked to see if it is weak. I do not think you have a weak starter... I will put money on it that it's the selenoid. Most parts places like autozone will check your starter free of charge.
Old Apr 22, 2003 | 01:28 PM
rezinn's Avatar
Even if you're running 10.5:1, you don't really need a high torque starter. I've got better things to spend my money on, and the stock one works fine for me.
Old Apr 22, 2003 | 04:23 PM
irocbsa's Avatar
I got sick of dealing with heavy ***, stock, POS starters from Autozone. I finally broke down and got an LT1 starter for $110. It sounds so much better than the stocker and is easier to remove if need be.
Old Apr 22, 2003 | 08:58 PM
gtabadboy's Avatar
Damn 110... for another 30 or 40 bucks you can get the summit high torque mini starter. That's the route I took. For his application I would just stick with the cheap one.
Old May 6, 2003 | 08:19 PM
Impoeatr's Avatar
hey...i have a 1991 Z28 with a 305 tuned port...sounds like i may have the same prob...starts up great cold...but after shut down and after a nice hot soak i get a slow crank and eventually it turns over...sometimes however fast crank? no turn over...i replaced the starter mayb 2 years ago (brand new ac-delco) for a different prob...battery is 4 months old (interstate)...starter relay brand new...starter cables (brand new ac-delco)...as u can c i dont use cheap junk on my car...but if any1 has had the same problem as i have please reply...im goin crazy!!
Old May 6, 2003 | 08:57 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Where is your initial timing set? If it's advanced too far you can have this same problem.
Old May 9, 2003 | 10:06 PM
Ryknow86's Avatar
Car: 84 Camaro Z28
Engine: carbed 350
i have the same problem, when i run the car for a while and shut it off it wont start back up. im going to replace the soleniod and get a heat shield. if i get the remote soleniod will that solve the problem (is it the starter that gets too hot or the soleniod?) thanks for any replies.
Old May 10, 2003 | 01:31 AM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
I second that, same thing happened to me. And the cheap bulky starter is what I use. If the timing is right, I dont give a damn how hot it is, it should work.
3rd gen money
Oct 11, 2019 09:57 PM
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
