I get mad when I am at WOT and a minivan passes me!!!!
Old Apr 10, 2003 | 02:12 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hey guys,
I was leaving school today and this kid who I know was behind me in a plymouth voyager minivan. He was on my A$$, and I punched it to get away from him, so he switches lanes and passes me at WOT!!! What are these 3.1's worth nothing? I cant even beat a **** minivan? What can I do to change this.
Old Apr 10, 2003 | 02:19 PM
CrispyClutch's Avatar
Maybe he had NOS...2 of them...big ones?
Sounds like you need a tuneup, or atleast kick the fat chicks out of the car.
Old Apr 10, 2003 | 02:38 PM
metalgod's Avatar
Ur car, is it an automatic? You Probably have 3.23 gears, possibly 3.08. A cheap mod that worked for me was getting a rear end from a 4 cyl stick 83 model camaro/firebird (3.70 RATIO) now some had 3.42's which aint bad either but i think the 3.70 ratio was a GT4 option code you can find in the console between the seats. you can get those rear ends fairly cheap from a salvage yard. the reason also that he blew past you might be the minivan was newer, and front wheel drive takes less power to turn. By putting the 3.70 ratio rear end in ur car, you are doing the same. so ur car will definitly accelerate faster. another mod is to set ur TPS, although ppl say it doent make a difference, it does. the TPS setting is probably @ .60 volts. Set it @.7 -.74 volts. it is a speed density car, so you can easily goto .9 volts before it affects idle. also, get an adjustable fuel regulator, set it @ 45-50 psi. these are really cheap mods that will make a difference. id say up tp 50 bucks for the rear end and 50 bucks for the fuel regulator. Id personally for sure get the rearend and set the TPS up to .74 volts. it will pin u in the seat harder! Also, if the car needs a tune up, you can put one step hotter in it, ur car i think takes r43tsk, id put r44tsx (.060" gap). buddy has an 88 camaro we put r45tsx's in it and it runs well. hey, just giving you some cheap mods to get more power out of it.
Old Apr 10, 2003 | 02:43 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
A lot of minivans put out sick amounts of power. I know my moms minivan puts out 220 from the v6 and I have a hunch that it could beat my IROC 0-30
Old Apr 10, 2003 | 02:48 PM
metalgod's Avatar
NOT MY IROC man!! lol mine could beat them. i was just giving him some mods that were cheap enough just to do to make the car more powerful.
Old Apr 10, 2003 | 03:05 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I saw minivan in the topic...so I had to read. I see it was a Caravan...whew, sorry...
Old Apr 10, 2003 | 03:27 PM
metalgod's Avatar
you are runnin all that stuff with a stock TBI manifold??? Edelbrock makes a good one. also, i had an idea with my 89 rs. running a singleplane manifold (torker 2 i use) you run less carb. i was going to adapt my T/B to a squarebore/spreadbore adapter, than place it on the torquer 2 manifold. ive also seen this done with a manifold that supports 2 carbs, he had 2 t/b's that went pretty good. it was in a 84 vette. i know this sounds "barbaric", but it may have worked with heads around 170 cc's or better.
Old Apr 10, 2003 | 03:28 PM
metalgod's Avatar
also, what cam is that 210 duration? it sounds like a crane cam.
Old Apr 10, 2003 | 04:42 PM
Vader's Avatar
That minivan may have had a 3.3L V-6, and been almost the same weight as your ThirdGen. It likely didn't have a lot of wheelspin, either.
Old Apr 10, 2003 | 05:39 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
probably a 3.8, the 3.3's are pretty f'in slow.. i work on em every day ya i work for chrysler.. i know i know.. but they pay me pretty well one of the guys i work with has a bone stock 305 tpi trans am and i raced him with one of the newer 3.8 vans and pretty much ate him off the line and top end wise.. they're pretty quick for minivans.. run mid 16's stock.. lol theres actually a guy at the local drag strip around here that has a twin turbo set up on his 3.8 mini van and it eats my camaro for breakfast 11.3 in the 1/4th with a front wheel drive minivan.. haha
Old Apr 10, 2003 | 05:43 PM
metalgod's Avatar
my dad has a 3.3L dodge minivan and my Iroc stock will beat it 0 to anything
Old Apr 10, 2003 | 05:49 PM
89RsPower!'s Avatar
yea just about anything will.. those 3.3s are horrible engines.. slower then most engines half their size.. the 2.4 4 cylinder actually has better pick up
Old Apr 10, 2003 | 09:18 PM
yea but this thing looked like a four banger, it had hubcaps not rims, just makes me pissed that my nice thirdgen camaro loses to one of them damn family boxes.
Old Apr 10, 2003 | 09:27 PM
Sad part is i wasnt racing, he out accelerated me, and gears have nothing to do with it, the rpms climb at the right rate in my honest opinion (3.23 limited slip)
Old Apr 10, 2003 | 09:30 PM
metalgod's Avatar
those RS's are really turtles. the Irocs do a WHOLE lot better. if ur rs is a v-8, then it will definitely have 2.73 gears and with only 240 foot lbs max ur runnin VERY slow. get 3.42 from a 6 cylinder 2.8 camaro around a 88 ,model. this will liven that turtle effect. mostly, theres not much you can d performance wise with the engine. they are swirl head design (half the intake runner is blocked off) the already restrictive heads. getting heads off a 305 or even a 350 TPI motor will do WONDERS.
Old Apr 10, 2003 | 09:32 PM
metalgod's Avatar
even those very restrictive exhaust manifolds just wont run.there not even 2 inches out lol there like 1 and 5/8's lol the rs's dont even have a chance at beating anything.
Old Apr 10, 2003 | 09:40 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
Originally posted by CrispyClutch
...atleast kick the fat chicks out of the car.
Just cuz it is a camaro doesn't mean it is fast, just cuz it is a minivan doesn't mean it is slow. Why isn't this in the street racing/bs board anyway?
Old Apr 10, 2003 | 09:46 PM
metalgod's Avatar
its just odd cause i never got beat by a minivan.
Old Apr 10, 2003 | 10:06 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yup same here
sorry dude - i guess just tell the guy you werent giving it any throttle lol
Old Apr 10, 2003 | 10:30 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Re: I get mad when I am at WOT and a minivan passes me!!!!
Originally posted by PimpRod92RS
Hey guys,
This guy has V6, not a TBI V8. Anyways, the easiest thing would be to swap in a V8.
My folks have a 3.8 V6 caravan, can you say "tire smoke for ~40 or feet" (add a slight right turn if you can't imagine it). When ever my car was down, I loved beating my friends' civics back in HS with the mini-van. About the funniest thing I've read today, getting passed on the left by a minivan while at WOT. HAHAAHAH
Old Apr 11, 2003 | 01:59 AM
EYEROCK89's Avatar
Car: 1989 IROC
Engine: 5.7 / 350 cuid
Speaking of minivans, my mom had a 4.3 liter 98 GMC Safari van which is basically a cinder-block on wheels. However, that thing would freakin fly. I wasted so many cars with that thing. It would go from 0-100 (governor) in no time. I loved it.
Old Apr 11, 2003 | 02:31 AM
metalgod's Avatar
THE THING WITH MINIVANS IS, THEY REALLY "FEEL" AS IF THERE FLYIN. TRY RACING AN IROC OR TRANS AM WITH IT.
Old Apr 11, 2003 | 02:34 AM
EYEROCK89's Avatar
Car: 1989 IROC
I've got better sense than that...lol
Old Apr 11, 2003 | 02:41 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
My friend showed me this website ages ago.
It really makes you wonder.
http://www.turbovan.net/van.html
Old Apr 11, 2003 | 02:51 AM
nikh23's Avatar
yea i downloaded that video of the van against the Z, crazy stuff
Old Apr 11, 2003 | 02:53 AM
metalgod's Avatar
dude, were talking stock minivans, it would be embarrassing to have ur car wide open and get beat by one of them. why did the guy post this? i would have just not admitted it
Old Apr 11, 2003 | 08:18 AM
I am not trying to cover it up, but I think he was passing me when i started to gain on him. I just wish I could have a little advantage over a minivan lol.
Old Apr 11, 2003 | 08:27 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
GET THAT 3.1 OUT OF THERE !!!!
Old Apr 11, 2003 | 10:19 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
DODGE FUNNIES
Here's a funny laugh-your-@ss off video for you...
http://www.thedodgegarage.com/video/...supra_long.zip
Or check out the rest of the page: http://www.thedodgegarage.com
Funny.
Pac J
May 17, 2020 10:44 AM
racereese
Oct 3, 2015 03:46 PM
