What does running lean or rich do....
Old Apr 10, 2003 | 10:05 PM
iroc_cragg's Avatar
Everyone is always talkin about there cars running rich or lean. What does running rich or lean do to the car/engine. Also how do u tell if ur running rich or lean.
Old Apr 10, 2003 | 10:23 PM
Crisis's Avatar
the best way of knowing if youre running rich or lean is using a scan tool and analizing the BLMs... try and search for "winaldl"..
Rich means that the Air to fuel ratio has more fuel in it than it should... the ratio is normaly about 14.7:1.. if the ratio changes to lets say 10:1 then its rich... 17:1 and its lean.. lean meaning that there isn't enough fuel to consume all the oxigen..
running too rich isn't really that bad.. spark plug will go bad faster.. cloged cat etc.... the engine just might stall... bad milage..
Running lean however of waaaaaaay worse.. running lean will cause severe heat build up in the cylindars.. which might burn a hole in a piston.. melt valves... and so on...
i hope i explained it clear enough...
Old Apr 10, 2003 | 10:24 PM
iroc_cragg's Avatar
Yeah thanks. Where Can I get one of those scan tools.
Old Apr 10, 2003 | 10:26 PM
MadZ28's Avatar
Car: 91 Z28
First off you need a laptop and a cable to attach it to the car
http://www.customefis.com/winaldl.html
Thats the site of the program, learn more there.
Old Apr 10, 2003 | 11:30 PM
RJR99SS's Avatar
instead of spending a few grand on a labtop and an a/f scanner you can just pull a spark plug and read it. Tan on the ceramic means its right about where you want it, white means it's lean, black and sooty is rich...
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
squiggy2
Aug 9, 2015 09:30 PM
