What sensor is this, located on pass side??
Old Jul 22, 2000 | 10:40 AM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
Its on the pass. side head in between the the 3rd and 4th spark plugs. The connector that plugs into the sensor just broke and I would to find out what it is so I replace that connector. Thanks
Old Jul 22, 2000 | 10:41 AM
R Defever's Avatar
It almost sounds like the temperature sensor that turns the electric fan on and off. Do you have an electric fan?
85 Z28 (Soon to be GMPP 350 HO)
Headman Hedders and matching y-pipe, Edelbrock Performer, Ram Air, Accell cap and rotor, Accell Supercoil, 160 stat, highflow Catco converter, absolutely no other smog equipment, B&M shift kit, Rapidfires, numerous carb mods, and flex-a-light fan.
"If you think education is expensive, try ignorance."-Ben Franklin
Old Jul 22, 2000 | 11:25 AM
Car: 1992 Camaro
Engine: 350 miniram
I do have an electric fan. If that is the the temp. sensor, then this would probally be a good time to replace it with one of those switches that will turn my fan on at a lower temp. Anyway let me know what you think.
Old Jul 22, 2000 | 12:28 PM
ZBRA's Avatar
Car: 1972 Corvette
Yes. Replace it with the Hypertech sending unit and it will come with a new connector also. This was one of my best mods.
'91 Z28 Blue/Silver ZZ4/ZF6
328.4 RWHP 363.5 RWTQ
Old Jul 22, 2000 | 12:43 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
It is the temperature sending unit to the gauge in the dash. As far as I know the switch for the fans is located on the passenger side tank of the radiator. Bob
Old Jul 22, 2000 | 01:28 PM
R Defever's Avatar
No the temperature sensor that goes to the gauge is on the drivers side head. The sensor he is refering to IS the fan switch sensor.
Old Jul 22, 2000 | 01:33 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I agree with R Defever.
Old Jul 22, 2000 | 01:43 PM
Car: 1992 Camaro
Engine: 350 miniram
so we have come to an agreement on this, and It's alright to replace the unit with the one from hypertech??
Old Jul 22, 2000 | 06:48 PM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
My apologises i thought that was the gauge sensor and the drivers was the copmputer sensor....then the sensor in the radiator is for....?
Old Jul 22, 2000 | 07:48 PM
Car: 1992 Camaro
Engine: 350 miniram
I think the sensor on the driver side is the knock sensor, and the one in the radiator is what sends the signal to the temp guage in the dash.
Old Jul 22, 2000 | 09:37 PM
ShadowChild's Avatar
the one on the pass. side block beside the starter is the knock sensor and the one on the head is the fan thermostat thing. i would like to know what the one on the radiator is too. i noticed there was nothing hooked to mine. perhaps why my fans still wouldnt work after changing the switch and the relay.
87 Iroc-z and a 77 camaro currently being restored
http://satanzchild.isonfire.com
Old Jul 23, 2000 | 08:30 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
IIRC the sensor on the radiator is the low coolant sensor.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at:http://www.geocities.com/transam85tpi/TransAm.html
Old Jul 23, 2000 | 09:42 AM
SATURN5's Avatar
Car: 84 SVO
Transmission: WCT5
great! thanks for the info on the sensor in the radiator as mines not connected either and wasn't sure if I missed something in the harness changeover.I pulled the entire harness out of my Malibu and replaced it with the entire (fusebox,lights,etc) harness from the GTA. Bob
80 Chevy Malibu
305 TPI/700-R4
7.5 " 3.42 posi
Ported upper and lower intake,
214,224 duration .450I .465E lift
"worked" heads
22 lb injectors
custom chip in the works
complete frame-off done.
painting this fall.
Old Jul 23, 2000 | 11:11 AM
John'89L98's Avatar
So... Here's the final word? The gauge sending unit is in the driver's side head, the secondary fan switch is on the passenger's side, and the computer sending unit is at the front base of the manifold. Any disputes? - John '89 L98
69 Six Pack
Oct 5, 2015 07:51 PM
timonator
Aug 11, 2015 09:56 PM
wruiz
Aug 11, 2015 02:59 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
3rdgenparts
Aug 5, 2015 11:57 PM
