Aluminum shift knob and heat....
Aluminum shift **** and heat....
For those of you with an aluminum shift ****....does it get hot or just warm? And how bad is it from the tranny and from direct sunlight in the summer?
Thanks in advance for any replies!
Bugsy
Bugsy
When I was a kid I put one of these things on a car because I thought it looked cool. It did, but in the summer after sitting in the sun for a few hours it was hot enough to cook my first layer of skin onto it if grabbed it with a bare hand (little exaggeration, not much). I don't recall every using one again.
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
my megashifter would either burn my hand in the summer or freeze it in the winter, that was on the 83 and after i wrecked it i took it out and sold it, ill stick with stock in the '84
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
After I put tint across the top of the windshield, I never have had a problem with b&m mega getting hot. It cost me $20 at the local tint shop.
Well my windows are tinted so the sun won't always be an issue but that still sucks knowing it will get hot as hell. I really want the b&m quicksilver **** and I think I'll just make sure to keep the old leather **** in the car for times when it gets really hot.
But what about heat from the tranny? Does enough heat travel up to make the **** really hot?
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
my B&M handle gets hot enough to burn you. when i get out of the car somtimes i cover it with a sock or somthing.
Car: 1986 Firebird
Engine: 2.8 V6
I also have the B&M Megashifter; and I wear driving gloves all year round. No problems at all.
It's never been hot enough to burn the B&M emblem into my bare hand... uh, (looks around) not that I tried that... nope, not me... saw it in the .. I mean.. heard it on the radio once.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
KNIGHTE
Southern California Area
Oct 22, 2015 09:11 PM
