solved the no spark problem!!!
Old Apr 12, 2003 | 03:51 PM
madmax57's Avatar
ok putting mass air tunedport on my 57 chevy from 86 iroc...had no spark replaced everything!!!! no spark..after 3 weeks and 12 calls to painless wiring..i finally got it..........on the iroc harness going into the distributor bat+ tach terminals i clipped this for my 57 wired it in..no problem right WRONG!!!!!!!!!
there is a small resistor going to each term.. bat to tach....even tho it showed 12 volt going into the coil the 12 volts must have been grounding out....somewhere?? (no tach was hooked up?) clipped it out..instant spark fired right up!!! life is good again...just buttoniing up loose ends sounds healthy cant wait to road test...then to the track!!!
thanks to all who tried to help...and vader
max
Old Apr 12, 2003 | 08:48 PM
Vader's Avatar
Glad you got it. I'll be watching for a '57 TPI on the way to Byron...
Old Apr 13, 2003 | 02:23 AM
Raiden's Avatar
Are you talking about the wire where the grey connector is for the tac?
Old Apr 13, 2003 | 05:09 PM
madmax57's Avatar
this wasnt a wire it is a resistor of some sort that goes from tach to bat. at the cap once i cut that out no problem!! it was on a 86 iroc ? what its function was is unknown to me.
max
mddaniel
Sep 8, 2015 05:16 PM
db057
Sep 4, 2015 07:57 AM
CORV3TT3
Aug 23, 2015 11:26 AM
g.l.mos
Aug 22, 2015 12:02 AM
