a couple questions
Old Apr 12, 2003 | 07:25 PM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
a couple questions
I need a new starter so I need to know how many teeth are on my flywheel and if my stock starter is a staggered or inline bolt pattern thats for the help my car is in the sig
Old Apr 13, 2003 | 01:12 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
common some one help me please! some one gotta know
Old Apr 13, 2003 | 02:24 PM
Vader's Avatar
IIRC, the staggered starter is for a 168 T plate, and the straight bolt pattern is for the 153T (12-34/") flywheel.
Old Apr 13, 2003 | 03:00 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
how do i know how many teeth are on my fly wheel?
Old Apr 13, 2003 | 04:28 PM
Vader's Avatar
  1. Cut off all the teeth with a cold chisel or Sawzall. Put them in a bag, then count them;
  2. Mark one of the teeth with paint. Start counting as you rotate the engine around one full revolution. Stop counting when you reach the paint mark again;
  3. Measure the diameter of the flywheel. A 12-3/4" flywheel should have 153 teeth, and a 14" flywheel should have 168 teeth;
  4. Look at the starter mounting bolts. If they are in line, you should have the smaller 153T flywheel. If the inner bolt is offset, you should have the larger 168T flywheel.
My W.A.G. is that you have the smaller one unless you have a truck engine or perhaps a 400 CID.
Old Apr 13, 2003 | 05:04 PM
Engine: 355, 305
Axle/Gears: 3.73, ?
lol thank you i think i will go with # 4
Frozer!!!
Jan 19, 2024 04:55 PM
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
