Leaking T-Tops
Old Jul 22, 2000 | 05:45 PM
88Roc350TPI's Avatar
Leaking T-Tops
Hi there,
My T-Tops are leaking, and I want to replace the seals. Classic Industries sells a kit for the '82-92 Camaro for $149.95 that is 8 pieces and is supposedly all genuine GM parts. Problem is, they are out of stock right now and they said it could be up to a month before they have them again. I am painting my car in 2 weeks or less, and I want to remove my old seals and put new ones in after I'm done painting. Does anyone know someplace else that sells the T-Top seals at a reasonable price like that? Any help is appreciated, thanks
Old Jul 22, 2000 | 06:03 PM
92TRANSAMWS6's Avatar
I think J.C.Whitney has them. So does www.nextgenparts.com
92 Trans Am/WS6/305/5Speed/T-Tops/K&N filter/Flowmaster Muffler/Ported Plenum/more mods to come.
69 Camaro/427-currently undergoing restoration
Old Jul 22, 2000 | 06:06 PM
The problem with nextgen is that they don't sell all the pieces I need. The Classic Industries set has ALL the seals and the little rubber shields on the ends of the t-tops. Plus if you add up the price of all the pieces from the other sources, it's astronomical, and the local dealer isn't even sure if she can get all the seals anymore.
Old Jul 22, 2000 | 06:16 PM
CHCKLS's Avatar
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
Have you tried adjusting the "seat" for the T-tops?
Old Jul 22, 2000 | 09:45 PM
ShadowChild's Avatar
could always do what i do. mine is leaking up front right on my seat so i took it off and shoved a paper towel under it to get me by until i can afford to fix it
87 Iroc-z and a 77 camaro currently being restored
http://satanzchild.isonfire.com
Old Jul 22, 2000 | 10:04 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Frobozz,
What do you mean by ajusting the seat on the t-tops?Mine leak to and the seals look good (no cracks)figured leaked from stress from racing.
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,ported plenum,March
pulleys,Accel 8.8wires,supercoil,ign.mod.
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod
"The more I learn about women,the more
time & money I spend on my IROC"
Old Jul 22, 2000 | 10:50 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
He's talking about removing the A pillar plastic moulding and the B pillar plastic moulding and loosening the phillips screws that hold the guide hole plates (can't remember the proper nomenclature name) and moving them down a tad, maybe an 1/8 of an inch, if that. Retighten the screws, and see how much it helps. Just don't move them down too much, a friend of mine caused his driver's side T-Top to crack while turning into his driveway after adjusting his down too far. Hope this helps.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at:http://www.geocities.com/transam85tpi/TransAm.html
Old Jul 22, 2000 | 11:13 PM
CHCKLS's Avatar
Engine: 409 SR
Kevin is right, DO NOT lower more than an 1/8 th in. if you have the glass tops. If you have the plexi glass you can get away with a bit more but not to much, the plexi glass will give a bit more, and if anything, SFC, and strut tower brace will help.
Old Jul 22, 2000 | 11:52 PM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Thanx for the info.Will try to adjust 2morrow.
Old Jul 23, 2000 | 12:16 AM
I've adjusted the a and b pillar adjusters, but what's wrong is the seals where the windows roll up are shot, and GM changed the outer flap thingy from rubber to hard plastic on the new seal kits. Is Classic Industries the only place that sells it as a KIT at a lower price than buying separate pieces?
Old Jul 23, 2000 | 04:57 AM
cardude's Avatar
I'm also in need of new weatherstripping. I also checked classics and heard the same story. I ended up buying them from GM. They were twice what classics wanted, but they had all the pieces.
1989 T/A 5.7 WS6
1967 Camaro LS6 454
Old Jul 23, 2000 | 07:38 AM
ausrs's Avatar
try this link
have found these guys to be very helpfull and ***** has also http://www.sunroofdoctor.com/
they have most if not all that you need to fix (or at least get new rubbers)
Old Jul 23, 2000 | 04:28 PM
CHCKLS's Avatar
Engine: 409 SR
I would try SOFTSEAL as well......I think the website is www.sofseal.com not sure though.
Another thing about the seals for the window and T-top area is that if you use something like a silcone rub like BlackMagic about once every two weeks, you should never have a problem again with them leaking, I've had my 92 RS w/ T-tops and have had it for awhile now and I have yet to have a single problem them leaking...
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
blackandblue02
Sep 10, 2015 08:19 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
