starter perhaps?
Old Apr 13, 2003 | 03:15 PM
SlowMaro's Avatar
starter perhaps?
ok, ...car SITLL goes glug glug after i shut it off, and start it again....new theory here....starter is hanging up or not dis-engaging after it starts?? make sense/?? or impossible???
Old Apr 13, 2003 | 09:33 PM
89WS-6's Avatar
Well your theory is easy to check if your right, just see if the pinion gear (starter) is like stuck on the ring gear (flywheel). But another suggestion, is the hot start problem, that you can find in the technical articles section...
The article
What could be happening is your starter solenoid gets hot from your engine, and then stops functioning. So you install a ford mustang starter solenoid somewhere else, and solve the problem for a long time. Good luck.
Old Apr 13, 2003 | 09:41 PM
SlowMaro's Avatar
no the engine turns over, ...it just runs like crap afterwards.....is this apart of the solenoid problem????????
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
