Car will not start again after running for awhile
Question for you guys. I have a 1982 Camaro with a 350 chevy carburated. It starts up fine, but after you shut it off, it will not start back up again untill the engine cools down after a couple of hours. When you try to start it, it pops, and white smoke is dispersed from the carburator. It started doing this the end of last summer. Any help would be greatly appreciated.
Thanks,
Justin
1982 Camaro
Thanks,
Justin
1982 Camaro
Car: 1985 Iroc-z
Engine: 355 sbc
the problem relies in your starter. What you need is a cheap heat shield from any local part store and that will help alot but you will have to disconnect your battery wires and the 2 bolts that hold the starter to install the sheild onto the starter itself.
Never mind. I read it in your dignature after I posted (signatures don't appear in the Reply screens).
With the Holley 4160, you'll want to check the bowl level through the sight plugs, and verify that the throttle body is tightly attached to the main carb body.
Holleys? Percolate? Naaaaaaw..... never an almighty Holley!
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
I didn't really read the whole post, but seems to be either starter issue related to heat, or a timing issue, I am leaning toward's issue with timing....
BC
BC
theshackle
Mar 5, 2017 06:37 PM
db057
Aug 11, 2015 10:11 PM
