Power Steering Pump
Old Jul 24, 2000 | 12:59 PM
jichniow's Avatar
Car: 89 IROC-Z
Engine: 6.0L LQ4
Transmission: 4l60e
Axle/Gears: 3.70
Power Steering Pump
Do I need to remove the Power steering pump pulley to remove the whole pump??
My service manual seems to call for it but I'd like to ge the whole thing off as one piece since I don't have a puller and can't really afford one.
Old Jul 24, 2000 | 01:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You shouldn't have to pull the pulley to get the pump off.
But if you do have to remove the pulley for some reason, you can "rent" a puller/pusher from Auto Zone and elsewhere, for free.
Old Jul 24, 2000 | 01:38 PM
daniel dekay's Avatar
dont rent one, i picked up a puller and a installer for my harmonic balancer for 30 bucks. i dont know if the pulley for the power steering pump is different from any other pump, say the water pump pulley, but i used 2 wrenches to get my water pump pulley off and on.
Old Jul 24, 2000 | 02:17 PM
monte-ss's Avatar
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
power steering pump pulley is pressed on, have to take it off usually to get the pump out of the brackets, you can rent the puller from most parts stores just a deposit and get it all back when you are done
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
Glowsock
Jul 24, 2025 03:15 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
