CAN any1 tell me how to get rid of this PING!!!!
Old Jul 23, 2000 | 01:04 AM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I have the most annoying ping in my car, and it only does it on hard acceleration or just flooring it, some1 told me maybe the guy who had it before my advanced the spark and maybe it causes a ping, I don't know, need ideas.
Old Jul 23, 2000 | 03:11 AM
3.1 firebird's Avatar
back off the timing. use better fuel.
Old Jul 23, 2000 | 10:26 AM
Dr. Pepper's Avatar
Trying a higher grade of fuel or a different gas station is a good starting point. What year is this car? If it is a later year you may have a knock sensor that is going out. Has the car always pinged like this is did it just pop up?
Old Jul 23, 2000 | 01:38 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I already use the best gas, and it started it just after I got it.
Old Jul 23, 2000 | 01:45 PM
JAMES POLEDNA's Avatar
ah...the best gas from your current store or the best gas available. I had this prob and it was the gas, I can only run High Grade from reputable service stations not conveince stores.
bought a wrecked(head on,bad)'84 Z28 rebuilt it in'92 parked it in
'93 and ordered a '93 Z28. Got tired of the 4th gen in '99 and sold it and begin swapping in '85 TPI converted to speed density. engine is all stock except for comp cam. body has '86 IROC nose peice,ground fx and IROC wheels/goodyear 245/50's. IMO this car looks and feels more "racey" than my '93 did. and I love driving it. BTW fuel injection is great I'll never go back to carbs.
Old Jul 23, 2000 | 01:52 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I use the best gas available ONLY, I woun't use anything else, so I'm kinda sure its not the gas.
Old Jul 23, 2000 | 02:02 PM
Dr. Pepper's Avatar
Try a different store. They may have contaminated their tanks or gotten a bad shipment or something. If you haven't tried the gas from a different source then you can't eliminate the gas. I would just try a different name brand gas from another location.
Old Jul 23, 2000 | 02:08 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I have tried using different gas and it didn't help, so now I just stay with the best, like I said I really don't think its the gas, any other suggestions or things to try??
Old Jul 23, 2000 | 04:57 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Check your timing it should be at 6 degrees BTDC. Also check your knock sensor, it might not be working. What is your water temperature at, is it possible that your thermostat or fans are not working correctly?
Old Jul 24, 2000 | 10:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
IROC-ZTWENTY, don't feel too bad... I've had a ping in my car since the day I got it. No amount of gas-brand-changing (always use 93 from major companies), timing changes, tuneups, computer chips, etc can get rid of it.
I'm leaning towards a partially clogged EGR tube (since EGR activation makes the computer go a big lean, or so I've heard)... but I've given up on fixing it.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jul 24, 2000 | 03:05 PM
IROC-ZTWENTYGR8
Guest
Posts: n/a
I know, I know TomP, but where is the knock senor located and how do u tell if its bad??
IROC ZELLER
Sep 29, 2015 03:00 PM
Zell1luk
Sep 29, 2015 10:36 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
the_hamturdler
Sep 22, 2015 02:59 AM
