My Z28 is down on power, need help!!!
Old Jul 20, 2000 | 11:32 AM
solidus's Avatar
I have a 1991 Camaro Z28 350 TPI w/dual cats.
I take it that both my cats are shot because they are tapping very loudly. I think I might have also put in some bad gas at the locat Cenex.
My question is: Why is my car down on power?
Could the cats alone be the problem, or is it probably the fuel filter, or both???
Thanks,
Solidus
'91 Camaro Z28 350 TPI dual cats
Everything stock
Old Jul 20, 2000 | 01:40 PM
1984L69Z28's Avatar
Having a plugged cat (let alone 2), will have a huge effect on performance. You can have all the air you want coming in, but without it flowing smoothly out, it is pointless. If you have had some bad fuel, a new fuel filter would be a good idea too.
1984 L69 Z28 with 350 H.O., Hypertech ThermoMaster Chip w/ 160* PowerStat, Stock L69 Dual Air Intake w/ K&N, L69 Dual Plane Intake Manifold, Modified Q-Jet, 350 4 bolt main w/ Crane Energizer Cam & 1.5 Roller Rockers, Lunati Drop Forged Crank and Rods, 23 Degree Trick Flow Heads, Hooker Comp Headers, 3:73 Posi, T-5 (Soon to be a T56!), 4-wheel disc brakes, 3" Catback Exhaust...etc.
Wise man say....Man who jump on bedspring this spring....have offspring next spring!
Old Jul 24, 2000 | 05:05 PM
solidus's Avatar
Thanks,
But how do I know If my Cats are plugged?
All I know is when I drive it, the cats tap very loudly.
Everything stock
Old Jul 24, 2000 | 05:40 PM
Dragroc's Avatar
Car: 1989 Camaro IROC-Z28
Engine: D1SC Procharged 350
Transmission: D&D Performance built T-56
Axle/Gears: Moser 12-bolt 3.90
I would either have your cats replaced or cut off...I had my cat clog up on me back when I first bought it, and it effected performance majorly...I thought I had a ***** for a little while. I went to our local Muffler Shop, and had the cat cut off. When I left the place, I thought I had put new heads or gears in. The motor felt new, the power difference I couldn't believe. Just replace them anyways, I'm sure it needs it regardless.
1989 Chevrolet IROC-Z28 TPI ZZ4 with TH700R4 and 2.77:1 rearend gears:
-Gutted Air Boxes, Throttlebody coolant bypass, Hypertech Air Foil, Accell Superram Base Intake, Crane AFPR, AC delete, Smop pump delete, Hooker 1 5/8 Headers, Holley Ignition Module, Hypertech Custom PROM, B&M Megashifter...I know there is more, I just can't think of it right now!
jaridjohn
Jul 8, 2024 03:49 PM
diana227vegas
Jul 8, 2016 12:27 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
neekolzun
Aug 24, 2015 04:59 PM
