Question regarding dampener on 89 pbr calipers
Old Jul 24, 2000 | 01:18 PM
Rob -Formula-'s Avatar
Hi,
I can't seem to figure out how these mount onto the caliper assembly. Im talking about the weight or dampener that mounts on the e brake bracket somehow. Every way I try to mount the dampener it fits sloppily or not at all. Does anyone have a picture or can explain how these mount. I have a diagram from gm that is of little help. Thanks
Rob
'88 Formula 305 TBI, Jet-hot Edelbrock TES, SLP catback,
Open Element, Functional hood scoop, good intake casting,
9 bolt BW 3.45 Posi w/pbr disc setup, Spohn LCA's & Panhard,
Aluminum driveshaft, Trans-go shift kit, March underdrive,
Hypertech stage II, 160 stat, Bilstien shocks, Resistor mod..
Old Jul 24, 2000 | 01:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Altho these are the old-style rear disc calipers, I was missing the dampener entirely on the 84 3.73/posi/disc axle assembly I just purchased. I know what you mean about the diagram, I'm not sure how they'd be mounted either. Maybe you can run without 'em?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jul 24, 2000 | 02:04 PM
blak92!'s Avatar
All the dampener does is reduces the howl noise when backing up.
Old Jul 24, 2000 | 02:20 PM
Thanks for the info Blak92. I would still like to bolt these on though. There are two possible holes on the brackets but it seems the actual dampener rests loosely on the assembly. Any ideas?
Old Jul 24, 2000 | 07:33 PM
Come on...someone has to know this.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Eric-86sc
Apr 3, 2016 03:52 PM
lt1z350
Brakes
Sep 12, 2015 09:28 PM
redmaroz
Aug 16, 2015 11:40 PM
