what is the best aftermarket intake manifold (carb)
I currently have a LG4 305 wich is all stock, and has an intake manifold that is leaking, I was thinking about replaceing the stock manifold with an aftermarket, which works the best? also it would have to be able to pass emissions, as I drive the car every day, I was thinking Edelbrock, any suggestions or help would be great, also a good carbureator.
Morgan
Morgan
A LOT of people run Edelbrocks, and most seem to like them. I might run a Weiand on my LG4 just to be a little bit different. You can check out their site http://www.holley.com/HiOctn/ProdLine/Weiand.html there.
And from everything I've heard, the stock carb is very good with proper tuning, and can handle a lot of HP.
I have an L69 with a edelbrock performer and a holley 600. Dont get a holley if you do not have much mechanical experience. They work great when set up correctly, but it takes quite a bit of experience to fine tune them. I like the edelbrock performer, they are very common because they are a nice design. I bought mine for $40 at a swap meet. If you get a used one make sure the machined surfaces are flat and the carb holes are not stripped. I had to helicoil 2 of them.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You have a few choices for your motor:
Emissions
Perfomer EGR #3701
Weiand Action-Plus EGR
Weiand Team G Street Ram (yes it has EGR!)
Non-Emissions
Edelbrock Performer
Edelbrock Performer RPM Q-Jet
Weiand Action-Plus
Holley Contender
Weiand Action-Plus
Paul Huryk, billionare in training.
Monkey Guy Racing
Almost part of the moderately infamous NJ in-your-face all goomba crew
Do it right the first time.
Paul's home page
1985 IROC LG4 POS Best: 15.20s at 92.1mph
1984 Camaro 350 LG4 Best: 12.21s at 121.7mph
The smart person pays for something today so that more is received tomorrow.
The ignorant person gets something today and hopes to have enough money to pay for it tomorrow.
Emissions
Perfomer EGR #3701
Non-Emissions
Edelbrock Performer
Weiand Action-Plus
Holley Contender
Weiand Action-Plus
Monkey Guy Racing
Paul's home page
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Edelbrock Performer, modified to fit centerbolt heads.
I like it. It's making power to 6000 RPM with the Comp XE262H cam, a Crane Hi-6 ignition, and the computer controlled Quadrajet with AU metering rods from JET performance and a "B" hanger from Edelbrock.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Daniel Burk
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
