What causes backfiring during acceleration?
Old Jul 21, 2000 | 05:30 PM
Ratnose86SC's Avatar
I think its from a lean condition.
Also, would a bad ECM on an LG4 have too much of an effect?
And, whats that ticking noise i always hear under acceleration?
Old Jul 21, 2000 | 07:50 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Is it a steady pop pop pop pop pop
ONLY when on the throttle.
Or is it just a pop and then its OK.??
ASE Mechanic/Machinist/Smog Tech
RTKTGTR 1999 NBM T/A, flowmaster,FRA,Pro Kit,BMR STB, polished calipers.
1986 Chevy 3/4 ton pick up,flowmasters,4.10s,
1981 corvette FOR SALE
1995 ZX6R,Yosh,D207s
GO #3
Old Jul 22, 2000 | 12:23 AM
Its just an occasional pop.
Only when under load also. No popping just reving. I got it to stop a little bumping up the timing.
Yeah theres a ticking in the valve train area, and someone else suggested a valve spring.
Old Jul 22, 2000 | 12:25 AM
Mike92's Avatar
My car does that when I apply throttle at less than 2000 rpms and it gets worse as it heats up. It becomes unbearable after a half hour or more of driving. What are all the causes to check in order to fix this? thanks
305TBI FireBird, Holley Intake and TBI, Headers, Torquer Heads, Gears. Best E.T. 15.08 at 92.5, 0-60 6.45.(Before Heads)
Old Jul 23, 2000 | 01:21 AM
BTTT
Old Jul 23, 2000 | 01:50 AM
No one stays up in the wee-hours of the night waiting to help their fellow third-genner?
Whats wrong with you people?
86 Sports Coupe/red paint faded to pink with white lines from rubbing compound.
Next project - spray can investment.
LG4. T5 soon(maybe)....yeah thats it.
Old Jul 23, 2000 | 02:19 AM
Teddy Z's Avatar
My previous Camaro ('85 MPFI V6) use to do the pop when I floored it. As it began to run worse I took it in for a tune up. The mechanic figured I had water in my fuel tank, threw in a bottle of water-b-gone and a new fuel filter and it ran great after with no pops. It could be that simple! Later, Teddy Z '84Z28
Old Jul 23, 2000 | 04:16 AM
Yeah ill get a fuel filter and run some fuel system cleaner through it.
Im gonna be busy tomorrow.
Old Jul 24, 2000 | 08:58 PM
Well it was the plugs, i took out the **** Bosch supers, and put in some regular AC Delcos. Also a new fuel filter.
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
racereese
Oct 3, 2015 03:46 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Racerx974
Sep 19, 2015 10:16 AM
