Late model manifold, early style heads
Old Jul 24, 2000 | 05:57 PM
freeze92's Avatar
I have a set of trick flow heads I am going to use on my new engine. Has anyone actually done the "slotting" of the center two bolt holes to install a late model (87+) manifold on early style heads? What is involved? Thanks.
Old Jul 24, 2000 | 06:38 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
You can do it with a dremel tool with a stone bit or wit a drill and a drill bit.The dremel tool makes it alot easier to elongae the hole.
Superman
Rev'n to Seven
Old Jul 24, 2000 | 09:09 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Yup! I did it with a circular file and a die grinder. I used the die grinder to make the coarse cuts, then used the circular file for the final finish-work.
Actually, I adapted an early style intake to late-model heads.
Worked like a charm.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Frozer!!!
Jan 19, 2024 04:55 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
