Gm crate motors????
Gm crate motors????
I may have an opportunity to get a gm crate motor for cost. Which gm crate engine di you guys reccomned if I want to keep my TPI from my 85 TA???
Brian
[This message has been edited by Smash (edited July 23, 2000).]
Brian
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The ZZ502 would be nice. I saw one in a vette the other day.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The ZZ4 is very nice, and it will bolt up to your 85 setup. However the heads dont have EGR, so you wont pass smog if that is a problem in your state.
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
Webmaster: ICON Motorsports
1991 Camaro Z28
5.7L 5-Speed
13.25 @ 107.18 MPH
Southern California
I put the 350 ho on my 85 tpi ta, however, i also changed the cam to the zz4 roller cam and i love it. it gives pritty good bang for the buck. i would go with the zz4 if i were to do it again, even more bang, but even more buck.
I need to pass a smog test. However, they don't do a visual inspection. they only do the sniffer test at a local garage. i have it poretty much narrowed down to the ZZ4, 350HO or the 92-93 caprice engine. decisions decisions....
Brian
Brian
I dont have any computer problems on mine, and its speed density!
I have gotten a code 32 (EGR) once or twice, but they are very rare.
Car: '89 GTA
Engine: ZZ6TPI
You have a couple of options. If you pick up a Corvette EGR valve, you can run a tube from one manifold to the valve to operate the EGR if you wish to run a ZZ4.
To use the 350HO, you'll have to wait until the vortec TPI base comes out in October, and you'll still have to run a tube, but the base has provisions for that.
The Caprice motor will require an 87' up intake base, and the cam is a little lamer than the L98
If you look in the index section of SDPC2000 under F-body and then crate engines, there are 3 hidden there.
1.) stock L98 with zz4 rotating assmebly ($2100)
2.) H.O L98 with L31(vortec) cam and 285hp(no swirl ports) heads, ZZ4 rotating assembly ($2400)
3.) H.O L98 with Edelbrock Aluminum heads and everything mentioned in #2 ($2700)
These 3 will require an 87' and later lower base.
89 Transam GTA, a few bolt ons
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
I'm looking more towards a 350.
