Car runbs like crap when hot
Old Apr 18, 2003 | 11:08 PM
skahide's Avatar
Well the other day my car was running awsome, then i was at my girlfriends house for 2 hours, went out to leave and the car wouldnt start. It sounded like it wasnt getting a spark. so we checked it and it wasnt. We switched out the rotor cap and the control module and it started fine. problem solved, WRONG! So im then driving home and once the car temp gets over 155 then the engine starts to stutter. When i press on the gas it doesnt pick up and go, it stutters BAD!! but it only runs like that when im pushing on the gas and after it has warmed up to over the second line on the temp gauge (155). What could it be??
Old Apr 19, 2003 | 02:36 AM
2laneblacktop's Avatar
Well not knowing what you run for induction this may be totally wrong. But if you are running a carb you may want to check to see if your choke is sticking. Once the car warms up it will not need the mixture the choke supplies and will make the car run bad. If you really notice it under acceleration this maybe the cause.
Old Apr 19, 2003 | 07:36 PM
skahide's Avatar
Well sorry guess i left out the good info. it is a 1988 camaro 2.8L V6 with MPFI.
Old Apr 20, 2003 | 09:56 AM
Vader's Avatar
Have you checked the oxygen sensor lately? Fuel pressure?
Old Apr 20, 2003 | 09:44 PM
skahide's Avatar
Is that the sensor in the air box? Tonight i noticed that the lights started to dim in and out if i was just coasting slowly without pressing on brakes or gas.
Old Apr 21, 2003 | 02:09 PM
skahide's Avatar
ok well i figured out this morning what was wrong with the lights, Dead battery. But i still have the problem with the stuttering. Could it be my filters, plugs, or plug wires?
Old Apr 21, 2003 | 06:37 PM
skahide's Avatar
NO ONE CAN HELP ME?
Old Apr 22, 2003 | 03:02 PM
firechicken_-54's Avatar
Car: 85 firebird
Engine: 2.8 HIPO
you should try the altinator, bring it to pep-boys and have them check it, if its bad buy a bosch alot of $$ but worth it
Old Apr 22, 2003 | 09:32 PM
skahide's Avatar
i had it checked and it was good. i had just bought it last summer. Im wondering if it is the spark plugs or spark plug wires cause it happens when it gets hot. How do you check the plugs or wires?
9192camaro
16
Feb 3, 2019 12:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
jackhammer
Aug 15, 2015 10:04 PM
mustangman65_79
Aug 11, 2015 03:17 PM
