Car won't crank
Old Apr 19, 2003 | 03:49 PM
pigsticker's Avatar
Car: 1992 z28
Engine: Vortec 350 TPI
Car won't crank
I have a 1992 z28 with the 350 TPI. The other day I was going down the road and it starting running rough and then died. I managed to get it cranked up and loped it home. I haven't had the car long and planned on doing some things to it. No big mods.I thought after I went through it my problem would go away, but I was wrong. Anyway here it goes. I've changed the plugs, put on a Blue streak brass cap and rotor, MSD 8.5 wires, an adjustable fuel pressure reg, replaced header gaskets. I've had my ignition module checked at Autozone, they said it was fine. I checked my pick-up coil and it checked out good. I replaced o-rings in the fuel rail and injectors. Fuel reg. is set at about 50 psi. The car will turn over and sometimes make a good effort to bust off but never does. I took my computer out to make sure the plugs were in good and found out it has a Hypertech chip in it I didn't know it had. I took my #1 plug wire off and put in an old plug and grounded it and turned the car over. The spark was not that great. It wasn't the strong blue spark I thought I'd see.Anybody know anything I haven't checked?
Old Apr 19, 2003 | 04:57 PM
ede's Avatar
ede
if you have a weak spark by checking with an old plug you don't have enough spark to light of the A/F mixture under compression. a strong spark would jump an inch gap pretty easy. i'd go back and recheck all the ignition parts.
Old Apr 20, 2003 | 10:22 AM
Vader's Avatar
Ignition coil, primary connections, grounds?
TheExaminer
Aug 26, 2015 04:59 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
ZsTransAm
Aug 11, 2015 07:30 PM
gwade12
Aug 8, 2015 08:17 AM
