1.6 rockers with Magnum 280H cam kit?
Old Apr 19, 2003 | 11:59 PM
DaytonaFBody's Avatar
I have a set of 1.6 RR SA (3/8" stud) that will fit on my heads. They were originally bought for my LT1 before it had a date with the guardrail.
Question is, will the valve springs that come from comp cams in the Magnum 280H kit coilbind on 1.6 rockers? What's the max lift for those springs...
And will they fit under side-bolt stock valve covers?
Old Apr 20, 2003 | 12:05 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Probably not because they should be SA rockers, if you have older then 86-87 heads you need non-SA rockers.
Old Apr 20, 2003 | 12:57 AM
86-350's Avatar
What is the lift of the cam?
As long as you don’t have vortech heads you should be all right.
The 1.6-1 " rockers will give you a bit more lift on your valve witch can be a very good thing. And if there roller rockers your looking at a easy 10 free hp.
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
