HOW do you GET the HEADLINER back IN!!!!????
Old Jul 24, 2000 | 08:55 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
I got it out, but how do you get the dang a pillars to clip back in? Is there some kind of trick to it??!!!!! I cant figure it out. I have been screwing around with this thing for a while now. How do I get it back in?
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
Clarion Head Unit,
Pioneer 6x9's,
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (17:24:14)
"No one knows until they learn" Leon Calrinsky (99)
Old Jul 25, 2000 | 10:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, there's a trick or two. And since I'm not a magician, I'll reveal them-
Hard Way: Hold the pillar cover against the top of the roof, and try to "slide" the cover back onto the clips. This way sucks, right?
Easy Way: Carefully use an awl/icepick/centerpunch etc to pry the white plastic clips out of the roof. I say be careful because these clips are very brittle from years & years of cooking in the sun's heat. Go slow and use as little force as you have to.
Now slide the white roof clips onto the a-pillar cover. Now snap the a-pillar cover back into the roof.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jul 25, 2000 | 11:31 AM
Kevin Irving's Avatar
Car: 1985 Trans Am
Your best bet would be to replace those clips, once they heat up like that and become brittle they are just as likely to break off the little barbs when you put them back in no matter how careful you are. They are like 45 cents at the dealer, although they are sometimes hard to find, the dealer I went through had to order mine.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Cyclone Fuel Pump, JET Airfoil
Veiw my car at: http://www.geocities.com/transam85tpi/TransAm.html
Old Jul 25, 2000 | 12:36 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Figured it out after trying the sliding idea...
Me and a buddy worked on it for at least an hour.
Pain in da butt.
We finally tryed to take the clips out of the holes, this was a pain in itself, but it sure made it a lot easier to get the pillars back on!
Thanks for the help. Job done!
Vintageracer
Jan 10, 2020 05:33 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
