Things I need to know about getting a tranny from a junk yard.
Old Apr 20, 2003 | 10:44 PM
Joeboy's Avatar
Im getting a tranny from a junkyard to go into my 82 Trans Am.Theres a TH350 in there now so Im going to stick with that. I need to know what size tail shaft I need. and if all TH350's have the holes for the support arm thats attached to the rearend (sorry dont know what thats called) . And is there anything else I need to know to be well informed. thanks for any help.
Old Apr 21, 2003 | 04:16 AM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
The support arm is the torque arm. Just make sure the tranny has a warranty for at least 30 days.
Old Apr 21, 2003 | 03:13 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Your trans is not a th350. it is a th250. It is simular.
No th350's have the torque arm mount. But B&M makes a good adapter kit to allow you to install a th350 in a third gen Fbody
and hook up the torque arm. It works well.
There are three tail shaft lengths on th350's {short med, and long.}
You can install all three of them but will need the coresponding right drive shaft. The short th350 is the same length as the stock fbody th250 you have now. (and most common 4 speed manuals and th2004r's). The medium length one is near the same length as a th700r4.
Generally the short th350's are found in older camaros, chevelles
etc The longer ones are found in large full size cars and trucks.
Dimensions
Case Overall Face To
Length Length Mount
TH350 (short) 21 5/8" 27 5/8" 20 3/8"
TH350 (long) 21 5/8" 30 5/8" 20 3/8"
TH400 (short) 4.375" 28 1/4" 26 3/4"
Th400 (long) 24 3/8" 34" 28"
200-4R 27 3/4" 27 3/4" 26 7/8"
700-R4 23 3/8" 30 3/4" 22 3/8"
700-R4 (vette) 23 3/8" 30" 22 3/8"
4L60E 23 3/8" 30 3/4" 22 3/8"
4L80E 26" 31 1/2" 30 3/8"
Old Apr 21, 2003 | 04:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A 250? You mean a 200C? Never heard of a 250... was this just an '82 thing?
Old Apr 21, 2003 | 06:04 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
THey made th250's but never put them in 3rd gens, they only had 200c's in 82 though.
Old Apr 21, 2003 | 06:55 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
does anyone have a picture of a th200c tranny pan? becuz i know my tranny is a th350 but now u guys are mentioning that the th200c is just like the th350. now the th350 tranny has the pan with a corner cut off i think its the bottem right if ur lookin at the back of the tranny. but does the TH200c have overdrive? if so then im pretty sure i have a th350 in my car.
Old Apr 21, 2003 | 07:46 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
remember to look at the fluid and make sure its still bright red and smell it, if it smells burnt I wouldn't get it.
I probably saved myself some troubles in the long run by doing that when I had my old car.
Old Apr 21, 2003 | 08:00 PM
flyin89's Avatar
Just look and see if it has a vacuum modulator if it does it is a TH350 if it doesn't it is a TH200/250. The pans look the same but has less bolts.
Old Apr 21, 2003 | 08:42 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yep but one big difference is the TH200c is stamped (METRIC) and TH350 or TH375 have no markings.
Old Apr 21, 2003 | 08:55 PM
ronterry's Avatar
Car: '94 Corvette
Pan bolts
11 = 200C
13 = 350
If you still need a picture of a 200c just scream. I have one sitting in my garage.
BTW: I've bought trannies at the boneyard, but only to rebuild them. Iiiii don't know if I would trust a transmission sitting in mud for 5 years.
Also I only pay about 50 bucks for TH-350's as is. Yeap - drained about two quarts of mud and sand out of them.
Ron
Old Apr 21, 2003 | 11:37 PM
Joeboy's Avatar
I think I changed my mind. I decided to have the mine rebuilt. When I talked to the guy from the junkyard he told me that he would charge me like 350 for a tranny and he actually suggested it would be more economical to rebuild mine. especially if I take it out.
Old Apr 22, 2003 | 12:51 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Maybe this will help you find out what you have...
Attached Thumbnails Things I need to know about getting a tranny from a junk yard.-trannypans.jpg
Old Apr 22, 2003 | 01:08 AM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Yeah, be careful the 200c and the 350 have very similar pans. I thought i had the original 200c till i changed the fluid and found that the 200c gasket wasn't the right one.
Old Apr 22, 2003 | 01:54 AM
82Z28NAZ
Guest
Posts: n/a
early in the '83 model year the 200C was available as standard equipment. It was later dropped.
Old Apr 22, 2003 | 03:58 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
okay that picture helped alot, i do have a th350 then and i do have that vacume thing attached to thetranny. i had no line hooked to it orgionaly but when i had the tranny serviced the place hooked it up. how important is that vacume thingy?
sweet_87_iroc
Sep 25, 2015 10:01 PM
spaigo
Aug 21, 2015 07:46 PM
Bob88GTA
Aug 18, 2015 03:31 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
