valve adjustments...
Old Apr 21, 2003 | 01:11 AM
SlowMaro's Avatar
ok so ive heard 1/4 a turn after the clicking stops, then ive heard 1/2.....so which is it????????with the engine running i mean
Old Apr 21, 2003 | 05:41 AM
ede's Avatar
ede
i go more than 1/2, less than 3/4
Old Apr 21, 2003 | 08:58 AM
No4NJunk's Avatar
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I've heard a few different amounts from friends and coworkers but I usually go about 3/4 turn.
Old Apr 21, 2003 | 09:17 AM
Vader's Avatar
Factory specs across the years were 1/2, 5/8, and 1 turn after zero lash, depending on the cam profiles and intended engine use. For higher RPM use, I tend to go a little on the lighter side. For a factory "LA" cam, 1 turn is probably acceptable. That puts you about halfway into the plunger travel in the lifter body, and will prevent you from having to adjust them again for a long time.
Old Apr 21, 2003 | 12:39 PM
SlowMaro's Avatar
ok well, i did half a turn to be safe....i wasnt sure i f the lkt1 cam would hold 3/4 or one full turn....well, didnt know if the lift was that much greater, didnt wanna bend a valve...and i refuse to take the valve cover off the pass side again lol, all that smog crap....*** thats a PITA!!!
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
sleprock
Sep 24, 2015 04:33 PM
HikoriYami
Sep 21, 2015 07:11 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
