Need HELP FAST! w/ Pulley setup
Old Jul 25, 2000 | 07:29 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
I was hoping for some help in converting to a 2 v-belt upper water pump pulley. My old set-up had 3 grooves and the middle was for the smog pump. I "lost" my smog pump so I only need the two. Summit doesn't have a 84 Camaro replacement. I am going to try to fabricate something but if anyone can give some advice ahead of time that would be great. I have also condered removing the A/C but I think this is the pulley colsest to the block.
Old Jul 25, 2000 | 07:58 PM
ede's Avatar
ede
was in a similar position with a 88 i built a 355 for. it's hard to get what you have and what you find to work. i ended up geting every pully and bracket off a 350 truck. i'd guess a ny 305, 350, 4.3 or 3.8 would work as a donner.
Bubbajones_ya
Jul 6, 2024 08:32 PM
grngryoutmyway
Oct 18, 2016 05:48 PM
92-Formula
Dec 12, 2015 10:34 PM
customblackbird
Oct 1, 2015 04:30 PM
