Problems between 1000-1500 rpms
Old Apr 22, 2003 | 10:18 PM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I'm at loss here. Basically the car hesitates, shakes, and pops when first starting off in 1st, and then just has a really bad hesitation under 1500 rpms in all the other gears.
I changed EGR, TPS, MAT, Cap, Coil, Rotor, Plugs and Wires. Set the timing 6* and TPS .54. Not to mention, cleaning the Throttle Body and checking for vacuum leaks. I don't know what else to look for. Any help would be GREATLY appreciated. Thanx.
Jeremy
Old Apr 23, 2003 | 02:26 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
New air filter? maybe it just can't breathe. Thats probably NOT it, but you never know...
Old Apr 23, 2003 | 11:45 AM
jgifford's Avatar
Car: 1986 Z28
well have an update, tried advancing the timing to 8*, the problem got worse, so I backed it off to 4*, same story got worse. I also tried some K&N's and the situation remains. Could an o2 sensor be causing my problem, considering it pops under the car?
Jeremy
355tpipickup
Aug 27, 2015 08:13 AM
Regal105
Aug 23, 2015 03:45 PM
forstral
Aug 19, 2015 03:20 PM
hokis
Aug 9, 2015 03:57 PM
