need help with heat range plugs
Old Apr 25, 2003 | 08:20 PM
Psyte's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 600cfm carb
Transmission: 700R4 (auto)
ok, i have a carb on a tpi engine. im getting alot of detonation with my bosch platinum +4's and 92 octane, so im gona ditch the +4's and try something with a colder heat range (i was told to try this). only problem is i dont know how to get a plug with a colder heat range. if i used what "would" be the recommended plugs for a 5.7L TPI would that cure my detonation? tpi heads have higher compression so i would asume a "tpi" spark plug would have a colder heat range than a non tpi 5.7L engine? if anyone knows the exact "code" i can use to get the plug's i need i would be really grateful, AC delcos seem to be the plug of choice around here, someone also mentioned rapid fires. also, please dont tell me its timeing, i know 100% its not the timeing.
Old Apr 25, 2003 | 09:05 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
ac delco plugs are numbered with r40somthing numbers.
43 being two ranges colder than a 45.
you could start out with a r43ts.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
86IROC112
Aug 21, 2015 07:20 PM
