What do i put in place of the air tubes when removing?
Old Jul 26, 2000 | 05:13 PM
lucas's Avatar
I was going to remove the A.I.R. tubes on my exhaust manifolds this weekend to free up space in the engine compartment and was wondering what i could use to plug up the holes that they go into.
Old Jul 26, 2000 | 05:34 PM
R Defever's Avatar
Go to your local hardware store and get some plumbing plugs. The ones with the square nut on top. They have a tapered thread so they seal very well. Thats what i used before the headers and they never leaked. Just make good and sure that they're tight.
85 Z28 (Soon to be GMPP 350 HO)
Headman Hedders and matching y-pipe, Edelbrock Performer, Ram Air, Accell cap and rotor, Accell Supercoil, Bosch 8mm wires, 160 stat, highflow Catco converter, absolutely no other smog equipment, B&M shift kit, Rapidfires, numerous carb mods, and flex-a-light fan.
"If you think education is expensive, try ignorance."-Ben Franklin
Old Jul 26, 2000 | 05:43 PM
91Zman's Avatar
Car: 1991 Z28
Transmission: 4L60 automatic
I was just wondering what to do with the things the A.I.R. tubes are hooked to?What to plug up or remove,reason being is that I'm going to put headers on soon.
Red 1991 Z/28 350TPI
minor mods:Flowmaster(dual& catless),K&N filters and others possibly(bought used).
John Soule'
Meguiar's wax!
http://www.umount./thirdgen/rides/johnsoule/images/johnsoule1.jpg
Old Jul 26, 2000 | 05:54 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I mig'd the holes shut on mine.
80 Chevy Malibu
305 TPI/700-R4
7.5 " 3.42 posi
Ported upper and lower intake,
214,224 duration .450I .465E lift
"worked" heads
22 lb injectors
custom chip in the works
complete frame-off done.
painting this fall.
Old Jul 26, 2000 | 07:19 PM
gravitar's Avatar
I thought I was going to unscrew the AIR pipes from the manifolds on mine, but years of rust accumulation had a different fate in mind. I ended up just crimping the ends of the tubes over. Works good, leaks just a little, but looks ugly.
Old Jul 26, 2000 | 08:23 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Whatever you do don't use brass plugs from the hardware store, use zinc plated steel ones. The brass ones will melt and shoot out.
Guess how I know that! :>
Old Jul 26, 2000 | 09:14 PM
lucas's Avatar
what size will they be if you remember?
Old Jul 26, 2000 | 09:38 PM
Guest
Guest
Posts: n/a
Mine havent melted, and my car runs extremely hot to top that off.
1/4" NPT (pipe thread)
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 12, 2015 11:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
